what would you do?
Old Mar 24, 2004 | 06:53 PM
zrs's Avatar
zrs
what would you do?
I got the engine back but have some questions regarding 2 picture. In one picture there is a hole in the block located near where you would put a mechanical fuel pump. The other is located on the same area but on the oustide where it looks like they tried to add material to plug up a hole. The items are circled in red. What would you recommend I do?
Here are the pics:
Old Mar 24, 2004 | 07:28 PM
Rice Killer87's Avatar
hey man,neither of the pics worked for me,but i know they make a block-off plate for the mechanical fuel pump that u can buy.
not sure about the hole u were talkin about b/c i cant see the pic.
hope that helps
Old Mar 24, 2004 | 07:38 PM
zrs's Avatar
zrs
Thanks for the reply I will try again but a block off plate will not cure the problem.
Old Mar 24, 2004 | 07:39 PM
zrs's Avatar
zrs
Here is the other picture
Old Mar 24, 2004 | 08:52 PM
transxtreme's Avatar
I dk what your looking at, maybe its the hole where the rod comes through for the FP. If it doesnt matter just buy a block off plate. I cant say for sure because the pictures wont come up.
Old Mar 24, 2004 | 09:16 PM
zrs's Avatar
zrs
pictures now work.
Old Mar 25, 2004 | 01:38 PM
Z28SORR's Avatar
In the first pict. This is an alignment hole for machining and usually does not protrude into the fuel pump push rod cavity.
Look at the front of the block. If it does open into the fuel pump cavity your going to have to fill it, weld or epoxy, or you'll get an oil leak.
In the second pict. This just looks like crud to me, take a scraper or knife and see if it come off.
Old Mar 25, 2004 | 03:39 PM
zrs's Avatar
zrs
The hole is visible inthe front of the block and as for the second picture, I tried scraping it before when I first noticed it. I think they tried to weld a crack onthe block. I will have to send the shortblock back. Who nknows what else maybe wrong with the block. Thanks for the help.
Old Mar 26, 2004 | 10:09 AM
Z28SORR's Avatar
The shop should have Magnaflux'ed the block for cracks and imperfections. And told you that they found so you could make a decision, before welding anything.
Good luck
Old Mar 26, 2004 | 12:48 PM
zrs's Avatar
zrs
Z28SORR,
Thanks for the info. The engine will be going back this saturday.
Old Mar 26, 2004 | 02:40 PM
IROC-T's Avatar
Originally posted by zrs
pictures now work.
Won't open for me.
