Tubes Going Into My Headers???
Old Apr 8, 2004 | 07:28 PM
klumb15's Avatar
I just bought my car a few days ago, and the previous owner did an motor swap, and put a vette motor in it....but on the right side of the engine, there is a hole tapped into each header tube, then there is a big tube that splits off and feeds each tube of the header...the left side has the same thing but its not hooked up...the big tube has a spark plug jammed in it, and the little holes in the header tubes are capped off....What is this for? Do i need it? Can I just take it right off?
Old Apr 8, 2004 | 07:33 PM
klumb15's Avatar
I think it is A.I.R....it looks like this http://www.jegs.com/cgi-bin/ncommerc...59&prmenbr=361 all that crap on the top.....what does this do? and do i need it?
Old Apr 8, 2004 | 08:40 PM
Ryanrabbie's Avatar
Sounds like he swapped the motor and used emission compliant headers and didn't hook them up. They are for the AIR pump for the emissions and they run to the AIR pump and cats.
Old Apr 8, 2004 | 08:46 PM
klumb15's Avatar
so if i don't have emision testings, i can take them off right....how do i take the air pump out? do i need a new belt or what?
Old Apr 8, 2004 | 08:54 PM
Ryanrabbie's Avatar
u will need a shorter belt and I'm guessing it'll be a serpintine belt, but Goodyear or some other belt company should be able to easily help there. If there is no emissions were u are and won't be, then go ahead, but I suggest u hang onto these vital, and expensive to replace parts if needed later on. I would change the headers then if u remove the AIR system to "offraod" headers and go from there.
Old Apr 8, 2004 | 09:31 PM
aklim's Avatar
You would want to plug up the headers like in that pic with plug caps and take the rest of the smog stuff off and keep it till you need it. See this.
Old Apr 8, 2004 | 09:40 PM
klumb15's Avatar
my a/c and altenator are flip flopped in that picture, it must be because its a vette motor...i'll look into it more tomorrow and i'll try to figure something out...because those tubes are really cluttering up my engine bay...and i hate it because the A/C is different than a camaro, so a big tube is runnign from the compresser to the canister on the otherside of the engine bay, so that looks ugly as well, i'll try to figure out a way to make that more appealing too...
Old Apr 8, 2004 | 10:09 PM
Ryanrabbie's Avatar
Naw, my 87 Iroc had it switched too, my 88 is like the pic.
And u could always remove the AC for less weight, mine was a non AC car and I'm happy with it, also more room to work and if I get hot, take the roof out.
Old Apr 9, 2004 | 01:28 AM
aklim's Avatar
No diff if the AC and alternator are on opposite sides. You still take the same things out.
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
drptop70ss
May 4, 2015 08:22 PM
alphaauto
Jan 23, 2015 07:42 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
