Manifold Censor
Old Mar 31, 2004 | 02:26 PM
StalkerIROCZ's Avatar
Manifold Censor
There are 2 censors on the back of the Actual Tpi manifold not the plenum and i know one of them is the coolant temp But the is a Big one right next to it and i was woundering if any of you could tell me what it is.
Old Mar 31, 2004 | 05:27 PM
Rice Killer87's Avatar
u must mean the FRONT of the base correct? yes,1 is the CTS (coolant temp. sensor) and the other is IAT (intake air temp.) i THINK...im sure some1else will come in and clear this up.
Old Mar 31, 2004 | 06:21 PM
Damon's Avatar
CTS is up front near the TB. At the rear....... I can only think of one sensor back that far- the oil pressure switch which actually screws into the BLOCK just a tiny fraction of an inch behind the back of the intake manifold, just to the driver's side of the distributor.
Intake Air Temp sensor is screwed into the bottom of the intake plenum.
Old Mar 31, 2004 | 06:45 PM
Dave89IROC's Avatar
on the front of a 86 base is the CTS and the cold start injector switch
Old Apr 2, 2004 | 09:56 PM
That right Thanx man its the cold start switch the only thing i didnt think of Ill be danged. Than alot guys
GREEN3112
Feb 10, 2019 09:19 PM
HibachiZ28
Nov 6, 2015 12:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
ShiftyCapone
Aug 27, 2015 10:14 AM
Jmj93z28
Jul 8, 2015 06:58 AM
