what size tire??
Old Apr 8, 2004 | 10:44 PM
cals400ex's Avatar
what size tire??
i am getting tires on my 87 iroc 350. i have 17x8 inch iroc wheels. i am wanting a tire that is at least as wide as stock. we are looking for about the same height as stock too without clearance problems. what would go with??
Old Apr 8, 2004 | 11:13 PM
kandied91z's Avatar
245/45/17 is the proper size tire....if your worried about sidewall size if your not a good driver or this is a daily driver i might go 255/45/17 which is slightly taller but you'll have a little thicker sidewall.
Old Apr 9, 2004 | 07:58 PM
LiquidSkies's Avatar
255/45/17 is the sure way to go. more wall to protect the wheels from road conditions. possibly give you a better ride
Old Apr 16, 2004 | 10:59 AM
stevepark's Avatar
go to like tire kingdom...or any local tire distributer & they can look up the stock tire size on the computer......& they can tell what you can & shouldnt do with tire sizes
Old Apr 16, 2004 | 11:49 AM
buzz12586's Avatar
I went with 255/40/17's and it comes out to be the same overall tire diameter so you don't have to change your speedo. The ride is almost better than before and I came from 215/65/15's so I don't know.
Old Apr 16, 2004 | 08:02 PM
camaro05's Avatar
Check this sight out. it is awesome, even tells you how much your speedo will be affected.
Tire size calculator
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
shroyvin56
Apr 3, 2015 08:15 AM
cristian1311
Mar 4, 2015 04:45 PM
