Brakes?
Old Mar 27, 2004 | 12:18 AM
Bristol's Avatar
Brakes?
Its time to redo the brakes on my 91 Z28 1LE. Im not impressed at all with the stock setup. Im not sure if its the quality of th epads or the rotors but I want more stopping power. What pads do you guys recomend? Is it worth while getting drilled or slotted rotors? Ive heard that drilled ones tend to get cracks. If anyone has any experience please let me know your thoughts. Thanks.
Old Mar 27, 2004 | 01:12 AM
aklim's Avatar
I use performance friction -Z compound
Old Mar 27, 2004 | 01:27 AM
97WS6SCharged's Avatar
I've heard the same thing about drilled rotors cracking. The new rotors I've got for my 97 TA are made by Powerstop for a C5 Vette and they are dimpled and slotted. The dimples are supposed to work just as good as the drilled holes, but they don't weaken the support structure for the rotor.
Ps. I forgot, these rotors use directional vaines to keep them cool as well. You can only mount them one way. There's a left side and a right side, and you don't want to mix them up.
Old Mar 27, 2004 | 01:38 AM
kandied91z's Avatar
i have yet to have any problems with cross/slotted rotors however they have always been the nicer grade; gm/baer.
i wouldn't look to the rotors as an upgrade unless your going larger. if a 2 piston setup with good pads isn't good enough step up to 4. depending on your use my 13" 2 piston baer setup is more then enough on the street......i worry about those behind me all the time.
Old Mar 27, 2004 | 02:17 AM
aklim's Avatar
I think the company went out of business but I got mine from Jegs or Summit. GT Rotors is the name. Gold Iridite finish and they are dimple milled not cross drilled.
Old Mar 27, 2004 | 10:29 AM
I love stepping on the brakes and feeling the car do a nose dive. And I've got good shocks and springs in the car.
Old Mar 27, 2004 | 05:31 PM
aklim's Avatar
If you are going to change pads, you probably would want to bleed the brake lines. Why not change to a braided hose? I noticed that my pedal is more reactive to my hitting it than it used to be witht he rubber hose.
Old Mar 27, 2004 | 05:35 PM
kandied91z's Avatar
just upgrading the stock brakes with good pads and braided line makes a huge difference.
Old Mar 29, 2004 | 08:30 PM
WhiteKid's Avatar
Metalic brake pads might make less brake dust but its killer on the rotors. You'll probably have just about the same amount of rotor wear as you will have brake wear. Ceramics are a bit dusty but will wear the pads instead of the rotors. I just got Morse Ceramics from AutoZone and they stop nicely.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
