May use rear end gears from S10- or Monte-where can I decode the axle ratios?
Old Apr 2, 2004 | 11:26 AM
nuck's Avatar
I have a Haynes book that lets me know what the F body rear ends are by the numbers stamped on them. I am told the 80s S trucks and Monte Carlos have the same 10 bolt guts . Is there a site that has the decoding for these other rear ends? Are the other cars I should also be checking for? I need at least a 3.42 and hopefully posi.
Old Apr 2, 2004 | 03:53 PM
Rice Killer87's Avatar
not sure any sites,but u can count the # of teeth on the pinion and ring gear and divide the # of teeth on the pinion into the # of ring gear teeth to get the ratio.
not sure if thats what ur lookin for,but hope it helps
Old Apr 6, 2004 | 07:18 PM
LiquidSkies's Avatar
chiltons will tell you also. go down the the local book store and look them up so you dont have to buy the book
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
