idear
Old Mar 24, 2004 | 06:33 PM
chevyman502bb's Avatar
idear
found a really cool on/off switch, i wunna wire it into my switch so i can kill it in case some1 tries to steal my ride and they wont be able to start it......what do i cut into to do this?
Old Mar 24, 2004 | 07:35 PM
Rice Killer87's Avatar
the hot wire to the ign. switch.
theres also this cool thing my dad got off ebay for his 71 SS Chevelle...it goes on the neg. battery terminal and the cable bolts onto it and it has a screw on/off **** on it. if u take the **** off its just like taking off the neg. battery cable. in other words,nothing will work...the car wont start. sounds like a better idea to me then tryin to splice in a switch in the ignition system.
hope that helps
Old Mar 25, 2004 | 05:11 AM
94m5's Avatar
Both have been around for quite a while......Old school style dictated that you put the switch on the rocker panel under the drivers side door. I prefer on-star, and my insurance company.
Old Mar 25, 2004 | 10:36 AM
teke184's Avatar
how bout the wire in the fuse block going to the ECM?
you could also use it to clear codes when/if you need to, and if you park it for a while like at an airport.
Old Mar 25, 2004 | 01:08 PM
my ECM is comin out soon anyways so that wont work, i was planing on puttins it under the steering wheel hiden somewhere, but i like the idea oh doin it on the outside of the car too
Old Mar 25, 2004 | 08:51 PM
transxtreme's Avatar
Do what i did. Wire one up for your door locks in case u get locked out. I put mine on a switch inside the fog light tube. You have to get down and reach real far to use it so no one knows. SHhh. It has saved me a couple times. As for the disconnect use your vats wires. They are under the dash and easy to get at. Just splice it and run a switch to where ever, i was thinking about putting a switch in the console ashtray out back. As in open the ask tray up in the back, put your fingers up in it and flip the switch so its hidden and no one is the wiser.
Old Mar 25, 2004 | 09:13 PM
how did u wire it up for your locks?
Old Mar 26, 2004 | 04:10 PM
take your door panel off. Get at the wires leading from the lock switch. Use speaker wire to splice it with and just run the wire to where ever you want your switch to be.
Old Mar 26, 2004 | 04:38 PM
i dont have power locks
blackz151
Feb 5, 2005 04:50 PM
blackz151
Jan 31, 2005 09:46 PM
blackz151
Aug 9, 2003 08:19 PM
