BAD overheat
Old Apr 10, 2004 | 01:27 AM
transxtreme's Avatar
BAD overheat
Here is the deal fellas. I just finished putting my amp and subs into my RS and **** today. So i fire her and im letting her idle while me and all my buddies sit around and enjoy the new system. We go over to look at my buddies amp real quick and my other buddy screams and says holy **** your car is smoking. She was in idle, no reving at all, for about 20 mins tops. I shut her off right away and popped the hood. The water in the radiator overflow was boiling like crazy. My temp gauge was well past 260 to where it couldnt go any farther. The problem is the fan isnt turning on. I checked the fan fuse and its fine. I just drove her about 50 miles yeterday and she was great. Wats my problem.
I was thinking about just putting in a manual fan switch anyways but its poitless since its not a racecar yet.
Old Apr 10, 2004 | 01:30 AM
Zepher's Avatar
Sensor isn't working or the relay is bad.
Mine don't come on either so I wired up two switches to the relays so I can turn each one on and off at will.
I run the primary fan on all the time.
Old Apr 10, 2004 | 03:05 AM
aklim's Avatar
It should be cool enough to run the car without the fans. Something else is wrong.
Old Apr 10, 2004 | 04:35 AM
Zepher's Avatar
Uh, not when it's just sitting there.
Mine did the same thing, sat there idling and it almost hit 260.
With the 160stat and the primary fan on, the temp stays at 160-170.
Old Apr 10, 2004 | 08:58 AM
lordmetalz28's Avatar
i keep a spare fan relay in my center console cause that fan always gave me problems 2, try taking it of cleaning the contacts and using new contact grease, should be good till you buy another one, if it isnt that the temp sensor is bad, you may want to thing about getting the hypertech fan switch, works great
Old Apr 10, 2004 | 12:11 PM
krazzycowgirl's Avatar
I had that problem as well. fans wouldnt come on when they were suppost to & over heated my car. So We solved that problem. Hard wired the fans to the battery so everytime I start my car I have fans.
If nothing else drain your coolent system & change hoses/ a few other things put new stuff on fill her up & ya should be fine.
Old Apr 10, 2004 | 12:24 PM
aklim's Avatar
What ambient temp do you have? Last time I did it was in late winter witht he temp around 30-40 an I had not put the fans back in yet or forgot to hook them up, one of the two.
Old Apr 10, 2004 | 08:11 PM
Alright, thanks for all the help. Where is the fan relay located at? Also how did all you guys wire up your fans to a switch?
colts0455
Jul 24, 2015 04:51 PM
vwb11356
Jul 22, 2015 06:51 PM
Jmj93z28
Jul 8, 2015 06:58 AM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
