NEED answers right now! about posi unit..
Old Apr 3, 2004 | 02:38 PM
Wishmaster's Avatar
Im in the process right now of switching out my 2.73 factory posi rear end to a 3.42 gears SLP Torsen Posi rear.
I have both rear ends sitting beside each other on the garage floor. My question is,
When I turn an axle on the 87 factory posi both axles turn in the same direction along with the yoke.........but when I turn an axle on the SLP posi they turn in opposite directions and the yoke doesnt move.....but when I turn the yoke on the SLP posi then both axles turn in the same direction....why is that?
is it because the SLP unit is not locked?
I just find that ODD!.......
thanks guys!!!
Old Apr 3, 2004 | 04:29 PM
aklim's Avatar
My posi works the same way as your SLP unit. I don't believe your old one was posi, was it?
Old Apr 3, 2004 | 04:30 PM
Marc 85Z28's Avatar
That's normal. Never test for an open rear or posi rear by spinning a wheel. Spin the driveshaft/yoke.
Old Apr 3, 2004 | 05:43 PM
lordmetalz28's Avatar
speaking of odd rearends, whats the deal with my new ring and pinion bolts, the tighten when you loosen, as in if i where to take a socket and put it in the off position for every other bolt on the planet it will tighten my ring gear bolts and vice versa, is that normal
Old Apr 3, 2004 | 06:05 PM
Wishmaster's Avatar
WHEW!! that makes me feel better! I thought something was wrong with the SLP unit.....but I guess not.
Yeah my old rearend was factory posi with 2.73's
Old Apr 3, 2004 | 09:42 PM
aklim's Avatar
So they are reverse threaded bolts because they don't want them to come out when the item is rotating mostly in a certain direction
Old Apr 3, 2004 | 09:47 PM
that would make perfect sense , on a lighter note go yankees.
Old Apr 5, 2004 | 01:52 PM
trackbird's Avatar
Info:
http://www.torsen.com/general/general_faq.htm
Daluchman1974
Sep 11, 2015 06:12 AM
cmsmith
Aug 9, 2015 07:30 PM
vwb11356
Jul 22, 2015 06:51 PM
mrwz28
Jul 8, 2015 09:11 PM
