what should i put on my t top gaskets
Old Mar 28, 2004 | 02:50 PM
lordmetalz28's Avatar
will baby oil work, i dont have vasoline in this house.
Old Mar 28, 2004 | 03:56 PM
AutoRoc's Avatar
Spray Silicone?
Glitter? What's the problem? Leaking?
Old Mar 28, 2004 | 03:58 PM
klumb15's Avatar
its not like vasoline is that expensive, just go buy a little can of it for a couple of bucks... I don't think baby oil will work, well it will moisturize the gasket, but it won't seal it for a long period of time, like vasoline will. I usually just rub some armorall on it whevever I wash my car, and it seams to be just fine, at least it works for me.
Old Mar 28, 2004 | 04:11 PM
leaks under heavy rain just the back. where the rear seats are. in the deepest part of the back seat is where it collects water. just ran a silicone bead in the back and front portions. just wondering what i should do while i have em off. guess il pick up a little bottle of vasaline tommrow.
Old Mar 28, 2004 | 04:39 PM
aklim's Avatar
I apply silicone grease liberally and let it sit overnight and wipe the excess off in the moring. That is what I do for the door gaskets.
Old Mar 28, 2004 | 07:04 PM
8_4_berlinetta_'s Avatar
Dont put anything silicone based on seals I heard it will deteriate the rubber over time.
Old Mar 28, 2004 | 09:25 PM
PyRo9862's Avatar
I heard armorall dries things out over time. Whats wrong with silicone based stuff? I know petrolium based dries out stuff over time.
Old Mar 28, 2004 | 10:21 PM
i guess ill just leave them be since nobodys really sure
Old Mar 29, 2004 | 12:28 AM
aklim's Avatar
I don't know but I got some silicone grease from a GM dealership for the rubber gaskets and it cut down the wind noise some.
Old Mar 29, 2004 | 03:37 PM
krazzycowgirl's Avatar
Anything can dry out the seals out over time. But Even The Military on their seals use a petrolium base on all their seals.
Heck you got KY Jelly running around the house use that it works.
Old Mar 29, 2004 | 03:38 PM
klumb15's Avatar
well if its from a GM dealership, i'm sure it won't deteriate the rubber....but the universal spray silicone they sell at like kmart and stuff are a lot stronger, and can do more harm then good...I haven't had any problem with the armorall drying it out, but i apply it alot, so that might be the reson.
Old Mar 29, 2004 | 03:40 PM
klumb15's Avatar
I use KY jelly for more imporrtant things
Old Mar 29, 2004 | 03:44 PM
Dont get me wrong I sometimes buy stuff at the dealerships. BUT not everything they sell is always good for your car. Heck Not everything you buy for your car is good for it.
Old Mar 29, 2004 | 03:45 PM
I just know it works. I dont need to use it lol
Old Mar 29, 2004 | 05:29 PM
aklim's Avatar
The women I have been with never seemed to need it.
Seriously tho, they do tell you to beweare of certain lubricants when you wear rubbers so I am not sure if KY will hurt the rubber in the seals.
