new engine what should it rev at
Old Mar 24, 2004 | 05:36 PM
sewebb's Avatar
hello, i'm biulding a 355 and was wondering what it should rev at?
to figure what hyd cam to get.
355 chevy dart pro1 alum 215 2.05/1.60 heads, weiand stealth intake, holley 750 double pumper, .275 dome pistons comp magnum roller rockers, pete jackson drive gear. turbo 400 trans
stage 3 shift kit hd sprags. 456 gear not sure what size stall conv. to get yet.
its a bracket car but want to street every once in a while.
should it rev between 6500-7000?
Old Mar 24, 2004 | 07:37 PM
Rice Killer87's Avatar
Re: new engine what should it rev at
to make it semi streetable...yes
Old Mar 25, 2004 | 02:52 AM
dj haf's Avatar
if you wanna rev that high, may i suggest a rev kit?
Old Mar 25, 2004 | 12:13 PM
formularpm's Avatar
I would consider a solid roller.
Old Mar 25, 2004 | 07:14 PM
Marc 85Z28's Avatar
What's done to the shortblock?
Old Mar 26, 2004 | 02:51 PM
ws6transam's Avatar
There's some missing information here to determine whether or not your combination is going to be streetable or not, and where it should 'rev'.
Firstly, a 215 cc head on a 355 means there will be a lazy intake port on anything but a street/strip motor with high stall converter. How high? Well, that depends on where your peak torque will end up. Before you can calculate that, however, you need to pick a cam configuration and cam profile. Before you can pick the cam profile, you need to figure out your compression ratio. You'll also want to determine if you need titanuim retainers and buffalo sized valvesprings to hold it together at speed.
Then, there's the question of the shortblock, and if it can hold together at speed. With a 215 cc head and talk of brackets, I'd assume you have selected the right parts for the shortblock, and had it balanced. Things like QUALITY fasteners like ARP rod bolts, and not generic bolts that come from a no-name package kit from PAW.
So, questions in this order:
What's your compression ratio?
What's your cam configuration? hydraulic, solid, flat tappet, roller?
What's your roller rocker arm ratio?
What's your selected cam profile? (Call the experts at Comp Cams, Crane, or your cam manufacturer of choice)
Once you choose your cam, determined the proper valvesprings & retainers, and have calculated the engine torque curve, you should be able to make a more educated guess on the optimum torque converter stall, which is usually 500 to 800 RPM less than peak torque.
RUENUF
May 25, 2016 08:10 PM
Klypto
Mar 23, 2016 09:05 AM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Nostang 96z
Aug 31, 2002 12:01 PM
