K&N Air Filter to Throttle Body #
Old Apr 7, 2004 | 03:29 PM
WhiteKid's Avatar
I was wondering if anyone had the K&N air filter number that would screw right to the throttle body instead of going threw the air ducts. Its a TPI.
Thanks in advance
Old Apr 7, 2004 | 06:13 PM
LiquidSkies's Avatar
make sure you have a speed density setup and not a MAF. if you have MAF, the computer wont function properly
Old Apr 7, 2004 | 06:51 PM
WhiteKid's Avatar
thanks alot guys for your help.
Old Apr 7, 2004 | 07:39 PM
klumb15's Avatar
does this just fit the stock throttle body, or will it expand to fit a twin 58mm? because i might be getting a 58mm TB this winter, but i need an air filter right now...
Old Apr 8, 2004 | 03:04 AM
aziroc's Avatar
why would u want that??? all ur going to do is suck up hot air from the engien bay!
Old Apr 8, 2004 | 09:35 AM
aklim's Avatar
Re: K&N Air Filter to Throttle Body #
Thanks in advance
What year car? BTW, they are right that it will suck hot air unless you have some sort of ram air hood that plumbs cold air into the top of the engine
Old Apr 8, 2004 | 09:59 AM
klumb15's Avatar
even if you don't have plumbing to bring in cool air, it is way less restrictive than the stock thing with the 2 little sqaure filters...what would be the best place to pull nice cool air from?
Old Apr 8, 2004 | 10:03 AM
aziroc's Avatar
i have my airbox gutted and have the 2 square ones up front and my 406 has more then enough air.
Old Apr 8, 2004 | 10:15 AM
klumb15's Avatar
and whats the difference between one of these and an open element filter for a carbed or TB engine? people see dramastic changes when switching from stock aircleaner to open element, some people say its like dring a new car....and that sucks hot engine air...but does anybody know if this K&N 1000cfm will fit over a twin 58mm throttle body?
Old Apr 8, 2004 | 01:20 PM
aklim's Avatar
It has fit mine before except with the SR setup I have, it bumps into the hood but you should be fine.
Old Apr 8, 2004 | 07:52 PM
WhiteKid's Avatar
My air plumbing right now goes to a circular box and has a 3 inch opening aiming right towards a steel wall. It has 1/4" space between the wall and the opening to suck air in. The black piping rests on top of the radiator and that black piping gets REALLLY HOT. I could probably reroute the piping but I figured that black plastic is probably heating the air more then it would be if it was just engine bay air. I do eventually this summer want to get the RAM air hood like seen on the newer firebirds. I have a 92' Bird I know someone else asked. I work at AutoZone and I ordered one today. If I dont like it I'll just ship it back to K&N.
Thanks for the help. Some good points were brought up. Ill take them into consideration while making my decision.
Old Apr 8, 2004 | 09:27 PM
aklim's Avatar
SLP makes a cold Air induction kit for our cars. I have it and it is pretty decent.
Old Apr 9, 2004 | 07:27 PM
ive seen people actually drill a hole where the air filter sits on the firebirds and run it below the chassy, scooping up cold air from the ground. that must work a whole lot better then the restrictive stock setup, and better then the filter on the front of the throttle body. when at a stop, the filter on the throttle body will be sucking in hot air from the engine. i believe the throttle body filter would work a whole lot better then stock though.
Old Apr 10, 2004 | 01:39 AM
Zepher's Avatar
I put a large 8x4x3 K&N cone filter in place of the airbox on my 88 Formula. makes a loud sucking sound when I get on it now.
Best way for cold air is to fab up a setup like this,
This is a 4" mandrel bent tube that was originally on my friends 90 Formula 350.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
David Dorris
Jan 17, 2015 08:10 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
