getting car out of storage
Old Mar 28, 2004 | 10:44 PM
kevin 2.8's Avatar
there were tons of postsabout what to do to the car before it goes away for winter. i did everything i could for storage, changed atf, rear gear lube, full tank, take out battery, gasline storage stuff, bounty sheets etc...
so what do i do before i crank it up? ive heard dumping in some desiel fuel into the cylinders before you start it is good, but how much do i put in? do i fill it? and how far can i drive with the desiel in the oil, as the car is on a farm in the middle of nowhere.
Old Mar 29, 2004 | 12:30 AM
aklim's Avatar
I wouldn't put diesel fuel in the car.
If you are worried, I would make sure the battery is good, pull off the wire from the coil to the dist and crank it a bit to get the oil flowing and start it up. Then warm it up for a bit. DON'T BEAT ON IT for a bit.
Old Mar 29, 2004 | 03:06 PM
jawzforlife's Avatar
This year will be my 4 summer of taking the car out off storage.
I just plug the battery back in and start it up.
Old Mar 29, 2004 | 09:41 PM
Chris`s85Z28's Avatar
I make sure all the fluid is toped up and I also change the oil. Let it run for about 15 min. before you drive it so the oil and tranny fluid get hot
Old Mar 29, 2004 | 09:48 PM
lordmetalz28's Avatar
everybody told me not to but i start my iroc every week during the winter to keep it lubed , they say its the worst thing to do but for 2 years i never had any problems. i just change all the fluids in the spring
Old Mar 29, 2004 | 11:46 PM
PyRo9862's Avatar
I'm thinking that when its sitting for that long all the oil drains down into the pan, so instead of starting it like that once a year, your doing it every week. Where as if you drive it every day, there is probably still some oil throughout the motor when you go out to start it in the morning.
Old Mar 30, 2004 | 01:55 AM
kevin 2.8's Avatar
mines been sitting outside in the woods with all the critters since november
Old Mar 30, 2004 | 03:02 PM
kevin 2.8's Avatar
got it out today, drove it around
forgot how much i liked it. feels like drving a ping pong ball as apposed to a brick with my towncar
anywho i did take offf the coil plug and cranked it over before firing it up. good idea. it was raining pretty good out so i didnt want to spend much time doing it.
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
NewsBot
Dec 3, 2014 12:30 PM
owen66
Nov 30, 2014 04:21 PM
USAirman93
Nov 24, 2014 03:37 PM
