3rd Generation engine
Old Apr 5, 2004 | 09:39 AM
tiresmokinV8's Avatar
What engine options do I have for a '86 iroc?
I have an '86 iroc-z with the 305 HO carbed engine. I want 350hp or more but still remain emissions legal here in Ohio all they do is check the exhaust they dont check under the hood or anything. What do you guys recomend, most likely a 350 block but could I use a zz4 and swap over the emission units to it? Also it has a manual T-5 should I get it rebuilt or leave it alone or swap over to an automatic. Thanks
Old Apr 5, 2004 | 10:22 AM
stanghunter211's Avatar
GMPP offers an emissions legal swap for carbed cars from 82-87, basically its just that, a ZZ4 block with a nice cam, better flowing heads, tuned computer, intank fuel pump(replacing the block mounted one), and a dual snorkel air cleaner. There are a lot of other little goodies, the kit is supposed to come with its own 3" high flowing exhaust with high flow manifolds and what not. But yeah, I am sure you can still get it to pass smog as long as everything goes back on. I would think a fresh motor would actually burn cleaner than a seasoned L69... Good luck., check out the GMPP website for more info
WIll
Old Apr 5, 2004 | 11:38 AM
doug791's Avatar
i think the one key part is how much money do you have to spend on this project
Old Apr 5, 2004 | 09:45 PM
TheGreatJ's Avatar
That's the key part of every project.
Old Apr 6, 2004 | 07:10 PM
LiquidSkies's Avatar
well i must say the manual v auto is really up to you. if its stick, id leave it stick. if its auto, id leave it auto. more work and money to spend when you could be getting motor work done as for emissions, i dont see why you couldnt use a zz4 motor, as long as you keep your egr lines and the rest of the emo stuff. under the hood emission stuff you need for visuals but it doesnt do all that much for the sniffer. a nice cat will pass you on that. if your aiming for 350 hp, it will be easier to do with the 350 but you can acheve it with a 305. you know, you could just leave the 305 and pop a blower on top and they will get you over 300 hp easy
Old Apr 7, 2004 | 09:39 AM
How about the engines on Ebay? They are cheaper then the zz4 from Summit and advertise over 400hp for the complete engine that would be the same as the zz4 configuration wise wouldnt it? Id still be able to use the emmission stuff on it i would think. Are the advertised power on these engines on Ebay true or are they just saying it to sell them?Also what would I have to do with the t-5 for it to be able to hande the 350+ hp?
Old Apr 7, 2004 | 12:00 PM
doug791's Avatar
if you babied it would hold, one 3k clutch dump and youd frag the whole thing. The upgrade option would to either buy a used t-56 6 speed out of a 93-97 lt1 camaro or you can buy the same trannies new. Actually D&D performance sells modified viper t-56's to put in our cars for 2500.
Old Apr 7, 2004 | 06:56 PM
MY91Y84's Avatar
Thats pretty accurate seein how he has a NON WC T-5...they were garbage....the WC design is a little tougher.
Old Apr 8, 2004 | 12:05 AM
Vaneat-91RS's Avatar
WIll
It is my understanding that the Kit is no longer available through GM, unless you can find someone who still has one on hand such as Scroggins-Dicky. The parts are serviced individually, but no longer sold as a kit. This info was posted in the '03 GMPP catalogue.
Old Apr 8, 2004 | 12:19 AM
Good to know, I was unaware they stopped offering it like that. I had originally planned on doing this swap to my 86 LG4. Seems like the way to go for smog legal performance, But it had a nice price tag attached
Will
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
ChrisFrez
Jan 18, 2015 08:05 AM
Injuneer
Dec 15, 2014 09:36 AM
cmdeshon
Dec 12, 2014 10:51 PM
CaRParts102
Dec 6, 2014 08:45 AM
