some question about my gear experiences
Old Apr 8, 2004 | 11:28 PM
lordmetalz28's Avatar
drove my car home tonight on the highway, didnt mash the gas but put her half way down much faster i think, i went to a point where 3rd and forth where switching rapidly if i didnt move my foot once i pushed it in further it shifted into 4th, if i let off went to 3rd, she chirps every damn gear know except 4th, whatttttt a difference. not much juice on the highway, but thats ok, couldnt even chirp second with my 2,73
Old Apr 9, 2004 | 09:00 AM
trackbird's Avatar
Most 700R4 tranmissions will not stay in 4th gear when the throttle is floored (actually, it is closer to 1/2 or 2/3rds throttle). It will kick back down to 3rd gear. The Corvette transmissions (and the 350 Camaro/GTA/etc, as far as I know. The 700R4 I got from a 350 car as a core did shift to 4th wide open, so I know that at least a few did) would shift into 4th gear when "wide open". Too much gear will limit your top speed since you can't use 4th as an actual gear for acceleration. B&M makes a "kit" (it is a sleeve for the throttle valve assembly inside the transmission) that changes the forced downshift to about 75-80% throttle. I used that kit, it is a slight improvement, but I didn't think it was worth the cost/hassle for the slight improvement (my opinion). That is probably why you hit the point where it was switching between 3rd and 4th.
Have fun!
Old Apr 9, 2004 | 09:23 AM
aklim's Avatar
Have it rebuilt to shift when you want and how hard you want. Then followed by a performance engine.
Old Apr 9, 2004 | 02:47 PM
trackbird's Avatar
I believe that will require a different valve body. I've not seen a kit to allow you to upgrade to a setup that will shift into 4th at wide open. I had considered trying to buy the 4th gear valvetrain parts for the valve body of a corvette/350 F-body at one time, but never persued it. The B&M kit is the only "kit" that I am aware of (there may be others) that makes an attempt (and not a very good one) to correct this.
My thoughts.
Old Apr 9, 2004 | 05:50 PM
Talking
she acts wierd like unless i floor with shift in and out of every gear if i just push it halfway down. but once you give her gas shes fine, i think i have to study her more cause im not even sure what gear im in when i drive, mutch quicker but runs out of steam quicker to, headers on order
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Hurin
Dec 13, 2014 07:38 PM
