Intake/Sensor Questions
Old Mar 27, 2004 | 10:58 AM
firebirdjosh's Avatar
What is the sensor on the air box of my V6 firebird? It has 2 wires coming from it (black and tan). Its right before the MAF. I am just trying to get an understanding so I can replace the whole intake with a straight pipe. Also, how do I know if I need a new sensor and where can I get one? Anything would be appreciated. Thanks guys!
Old Mar 27, 2004 | 01:35 PM
IROC-T's Avatar
I believe it is the IAT sensor (inlet air temp.)
Old Mar 27, 2004 | 05:33 PM
aklim's Avatar
Without a scantool, it would be hard. You could have a thermometer in the inlet air and read the scantool to see how many degrees the air is. If you need a new one, you can get it from GM
Old Mar 28, 2004 | 07:41 AM
Thanks.
Old Mar 28, 2004 | 10:05 AM
Just curious, what does the ECM do when the temperature changes up or down?
Old Mar 28, 2004 | 10:26 AM
TheGreatJ's Avatar
Adjusts the fuel mixture if it's in open loop....if it's in closed loop, not much.
Old Mar 28, 2004 | 01:00 PM
http://www.cardomain.com/memberpage/243414/2
I am thinking about using hose like that. Opinions on that?
(I can work with tools, I just don't know alot about engines so I check here)
Old Mar 28, 2004 | 10:01 PM
slayer6x6's Avatar
Now thats different, Ive never seen that one before. Why dont you just glue a bunch of toilet paper rolls together?
Old Mar 29, 2004 | 12:26 AM
aklim's Avatar
What kind of hose is that silvery thing made of? Would it collapse under the vacuum?
Old Mar 30, 2004 | 08:45 PM
The guy seems to have had good results. I was skeptical of that too.
Old Apr 1, 2004 | 04:09 PM
slayer6x6's Avatar
Its only getting ported vacuum, so it shouldnt be over 3 in.
Old Apr 1, 2004 | 07:11 PM
aklim's Avatar
He is using a dryer hose of 4 in for the TB intake?
Old Apr 1, 2004 | 09:12 PM
Thats what it looks like.
Old Apr 1, 2004 | 11:42 PM
aklim's Avatar
I wouldn't. But that is just me.
Old Apr 2, 2004 | 06:09 PM
Maybe there is some re-enforced dryer piping there? I know the fire trucks around here have stuff that looks like that but is rigid plastic rather than just flimsy dryer pipe.
