different posi question
Old Apr 8, 2004 | 07:43 PM
allious's Avatar
i have a 3.45 stock posi unit under my 90 iroc. when i am stopped and try to make a really hard turn, especially to the left, it wants to "push" the front end instead of wanting to roll and turn. it does it forward and reverse. is this normal?
Old Apr 8, 2004 | 09:25 PM
aklim's Avatar
Doesn't sound normal. Sounds like your posi is locked up like having a spool.
Old Apr 9, 2004 | 07:28 AM
TheGreatJ's Avatar
Sounds like it's trying to lock up, or maybe someone has rebuilt it with an extra clutch or 2.
Old Apr 9, 2004 | 08:09 AM
aklim's Avatar
Can stock units be rebuilt? I know my Auburn one can.
Old Apr 9, 2004 | 08:23 AM
allious's Avatar
i am not sure. it will light both tires up from a dead stop , no torque braking necessary on this car. it just feels strange when you are trying to turn at very low speeds trying to get into a parking space or backing in or out of a tight area.
Old Apr 9, 2004 | 09:20 AM
aklim's Avatar
The posi will lock both tires so they spin equally. It will allow one tire to break free and turn more than the other when going into a turn. However, your unit sounds like it is not allowing it to break free in a turn.
Old Apr 9, 2004 | 07:38 PM
TheGreatJ's Avatar
The stockers can be rebuilt, but most just replace them. Since the SLP take-out posi was only $99 for so long it wasn't worth the trouble. It used to be common practice to rebuild them with an extra clutch (sometimes 2,) which tightened the posi substantially. It also caused it to wear out again sooner.
QuickSilver02
Apr 7, 2015 11:12 AM
blac94Z
29
Mar 25, 2015 04:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
