Aluminum driveshaft...what is the benefit?
Old Mar 26, 2004 | 01:15 PM
ZDADDY92's Avatar
Just curious what the overall benefit was of an aluminum driveshaft-just lighter so there is less weight to spin? How much lighter are they? Thanks in advance for any info. Have a good one-
Old Mar 26, 2004 | 02:40 PM
Bristol's Avatar
Less rotational mass = less vibration at higher rpms and speed
Old Mar 26, 2004 | 03:28 PM
klumb15's Avatar
are they worth it?
Old Mar 26, 2004 | 05:14 PM
lordmetalz28's Avatar
are they stronger then stock . i tend to think they wouldnt be. took a **** load of coke cans to make that drive shaft thats all i think about. lol ill be going with a heavy duty steel driveshaft myself.
Old Mar 26, 2004 | 05:28 PM
Stephen 87 IROC's Avatar
For a street car it will reduce or eliminate any driveline vibration. Forget about using a factory aluminum driveshaft if you intend to race. It won't last. I use a 3" x .083" steel shaft in my race car.
Old Mar 26, 2004 | 07:27 PM
kandied91z's Avatar
for a weekend warrior street car that is slightly modified to say no more then 300 or so horsepower i think they are nice...the extra weight you save in rotational mass is really felt in throttle response. if you get a deal on one or for even a $100 or so it's not a bad little improvement over the stock heavy piece.
if you plan or have any real power in the car though i'd advise against it....that or be sure to have a driveshaft loop. i twisted mine with only 300 horse and stock torque.
Old Mar 26, 2004 | 08:23 PM
aklim's Avatar
I would say that the AL driveshaft would be fine for an A4 because you are not dropping the clutch at 5000+ RPM and shocking the system that much.
Old Mar 26, 2004 | 09:22 PM
87DJP2001's Avatar
For a street car the Aluminum dr shaft is lighter by 4 lbs, less vibration at high speeds, spin up faster. Or in other words not much of a performance increase. But I do have a 1LE aluminum dr shaft on my car. Its just a nice upgrade over the stock steel one.
Old Mar 26, 2004 | 09:25 PM
97WS6SCharged's Avatar
I've got a 3 1/2" aluminum driveshaft in my TA that is pushing over 400 RWHP (should be higher with new cam and heads). I've never had a problem with it. Just use good U joints and yoke and have it balanced.
Old Mar 26, 2004 | 10:27 PM
ZDADDY92's Avatar
This is a factory aluminum driveshaft-I planed on having it balanced-I hope to have 400-425 hp-is this too much for that aluminum driveshaft? Opinions please!
Old Mar 26, 2004 | 10:44 PM
aklim's Avatar
Well, if I were to run a M5 like your sig, I would check the DS every now and then for twisting. Say at the end of every season?
Old Mar 27, 2004 | 01:36 AM
kandied91z's Avatar
as long as those number are at the crank, then yes! through some sticky tires and i'd say otherwise........
Old Mar 27, 2004 | 02:16 AM
aklim's Avatar
Yah but if he drops the clutch at 5500, that would shock the hell out of the drivetrain and that could be a problem. I would certainly get a driveshaft loop.
Old Mar 27, 2004 | 02:25 AM
kandied91z's Avatar
yes, either way with good power you should have one for safety.
Old Mar 27, 2004 | 03:18 AM
Nah, you'll snap the 7 1/2 rearend before you break a driveshaft.
