Oil Question...QUICK!!!
Old Apr 12, 2004 | 02:03 PM
klumb15's Avatar
how many quarts of oil do i need for my 90 corvette engine, i think its just the L98 engine...i already put 6 in, but its not full yet so i gotta go buy some more...how many more quarts do i need?
Old Apr 12, 2004 | 02:13 PM
Marc 85Z28's Avatar
With filter change it should only need 5 qts... Are you sure you're putting the dipstick all the way?
BTW - I'd drain that extra qt if I were you
Old Apr 12, 2004 | 02:30 PM
Rumblin91's Avatar
Without knowing what filter he's using and if he has an aftermarket oil pan you can't tell how many quarts it will take...
IROC-T's Avatar
You are checking the right dipstick ,and not the one for the trans,right? Unless there is an after market pan five quarts should fill it.
Old Apr 12, 2004 | 02:37 PM
klumb15's Avatar
i am pretty sure its a stock corvette oil pan, and the filter is just a regualar filter that i bought at kmart, the same size as the stock one.....but i dunno whats up, because the dipstick goes in all the way, and then when i pull it out, there is a little bit of oil on the whole dipstick like normal, then there is more on the very bottom, like it says it needs another quart but i can't see how it can't be full by now....this is the first oil change since i bought the car, a week ago, and on the dipstick there is a line scratched in it(sayin its the full mark or something), maybe its the wrong dipstick that is supposed to be on there or something...who knows, i guess i'll wait till my old man gets home from work...
Old Apr 12, 2004 | 02:46 PM
IROC-T's Avatar
Pull your dipstick out,and take a piece of fine sandpaper ,and sand the dipstick a little,wipe it clean and then try to read it. Some dipsticks are so smooth that the oil won't cling to them.
Old Apr 12, 2004 | 04:38 PM
lordmetalz28's Avatar
just put in 5 and drive, if your pans stock and your filter is stock like, just put in 5 and drive dont worry about it make sure your pressure is ok
Old Apr 12, 2004 | 09:22 PM
aklim's Avatar
5 quarts unless you have an aftermarket pan. I had a PF25 filter and when I changed it to a PF35, it took a little more than 5 quarts but certainly not 6 quarts. That crank will whip up excess oil into a foam and foam doesn't lubricate well.
Old Apr 13, 2004 | 12:37 AM
waltrip's Avatar
I think I'm a comedian, but I've just realized that I'm not funny. I just wanna apologize to you guys because I know that I should be embarrassed that I act like an idiot- and it brings down the quality of the board. Instead, I like being banned from tech forums. See you on Disneytalk.com!
Old Apr 13, 2004 | 02:08 AM
KnightRider350's Avatar
Unnecessary, unhelpful and reported.
Old Apr 13, 2004 | 12:01 PM
aklim's Avatar
Steve the mod does have a funny with this, doesn't he?
Old Apr 13, 2004 | 12:30 PM
Ahahaha...that's quality. You made my day Steve.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
