Will LT1 poly motor mounts fit 3rd Gen?
Old Apr 7, 2004 | 12:57 PM
zhevy-1's Avatar
I have a friend who has a 90-92 Camaro Z28 and he was looking for some motor mounts, and I just happen to have a set of poly ones that were for my 96 Z28. I want to know if these would fit on his 3rd gen?
Thx-Goose
Old Apr 7, 2004 | 06:30 PM
LiquidSkies's Avatar
i know when swapping the LT1 into a 3rd gen, the 3rd gens mounts can be used so i dont see why it cant go both ways. i would stick with the rubber mounts though, poly is GREAT but more road noise
Old Apr 8, 2004 | 03:33 PM
MrDude_1's Avatar
no.
they cant be used.
when swapping a LT1 into a 3rdgen, you must use 3rdgen mounts on the LT1.
the casting on the block matches between SBC and LT1, so the mounts bolt on to each other, but the chassis diffs make it not work.
he cant use them. sorry.
Old Apr 8, 2004 | 07:49 PM
im not so sure. i think they way the block bolts to the k member is the same. i know guys who swap the LT1 in sometimes use them, seen it done. i see what your saying though
Old Apr 9, 2004 | 12:39 AM
Zepher's Avatar
You can use one side, drivers side I believe. The pass side one is different.
Are the LT1 mounts you have just the inserts?
Does one of them look like this,
Old Apr 9, 2004 | 07:35 PM
ahhh Zepher, you are correct. i remember someone saying something about 1 side fits with the LT1 mounts. thanks for reminding me
Dec 31, 2014 02:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
1LEThumper
Jul 14, 2003 12:45 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
