406 short blocks
406 short blocks
hey guys im looking for a good short block to build a 406. looking for some one w/ a good rep! looking to make at least 450 hp / 500 of tq. so it must be a good block w/ forged pistons. also which is stronger a 350 4 bolt or a 400 2 bolt? and does anyone know how much it cost to convert 400 2 bolt to 4 bolt? all seggustions welcomed?
Thanks!!!!!!!
Thanks!!!!!!!
Originally posted by Mike86Z28
400 blocks. I have read there are too many problems with the 4bolt main's cracking(not the mains themselves but part of the block if I remember correctly)
See if you can find a 2 bolt 509 block (last 3 numbers of the casting #'s). These are the best blocks with the best metalurgy.
Are you looking for something other than the hundreds of reputible race shops that sell complete engines/shortblocks?
The more cubes the merrier too! A 400 2 bolt will be good with a stud kit. I'd feel good about it anyways. Goodluck!
want.to.know
I have a sb 406 in my 75 camaro. DO NOT go with a 4 bolt main they are much weaker than the 2 bolts. Depending on how much driveability u want out of the motor u can make all the power u will ever be able to put to the ground under 5500rpm. Mine has Pro-Topline 200cc runner heads 2.05/1.60 valves, Doug Herbert solid roller cam (custom grind), KB flat tops, rpm performer, and now using an 850 demon. With a th350,2500 stall and 3.73 gear i have went 7 flat motor and a 6.62 spraying 125 shot while breaking loose at mid track when i sprayed. Big thing to remember is balance out your tq and hp or u just gonna go up in smoke.
Originally posted by aziroc
<~~ 2 bolt 406...
if u want i can email u what all went into my engine(and what it has in it now) so u can get an idea of what u may want to look at.
<~~ 2 bolt 406...
thanks for the replies guys.
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
