roller lifters????
Old Apr 5, 2004 | 04:29 AM
sleepybu's Avatar
roller lifters????
whats the max lift you can go with a stock roller lifter befor you need aftermarket lifters
thanks
Old Apr 5, 2004 | 01:48 PM
aklim's Avatar
Seeing as how old your car might be and you are changing a cam, why not just get a new set of lifters that are aftermarket? I don't really know of a limit of the stock lifters but if I was changing cams in a car that had stock lifters, I would certainly get a new set unless I just put that set in 20K miles ago
Old Apr 6, 2004 | 02:06 AM
sleepybu's Avatar
i c....so i should just get retro rollers for my older block then getting a newer rollor block not looking to run a very big cam
Old Apr 6, 2004 | 04:11 AM
aklim's Avatar
Retro rollers are a little spendy so if you are going to change the block then get a roller block. If not, change to the retro lifters. If you are not running something severe, I don't see why there should be a question as to whether the rollers will hold or not.
Old Feb 3, 2007 | 12:42 PM
1LESSZ28's Avatar
thanks
old thread same quaestion. 68k on mine cam I'm looking at peaks just under 6k
Old Feb 3, 2007 | 02:55 PM
sleepybu's Avatar
Originally Posted by 1LESSZ28
old thread same ...
no kidding... almost 3 years old
Old Feb 3, 2007 | 05:39 PM
mdacton's Avatar
stockers are fine....for what you want to do
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
