what is the normal operating temp?
Old Mar 29, 2004 | 08:20 PM
BigDaddyWiz's Avatar
i know this has been discussed here a lot, i did a search about it and got a ton of post, but i didnt find one that answered my question which is this:
What is the normal operating temperature for my 84 z28 305 5.0 HO?
As some of you have seen i'm sure, i posted a few times about the thermostat and some heat issues i had. I put in a 180* thermostat and took out the 195* that was in there because it failed closed and caused the temp to rise up just below the red. Before I did this my temp gauge was always about level or a bit above the 220 mark. when i put in the 180* thermostat, the temperature would stay at or slightly above the second notch on the gauge(the one between 100 and 220) even in slight traffic. it cant be running at that low of temp now could it? according to the temp gauge, what would that be? the car runs fine and smooth even at this lower temp. is this ok on the engine? what i really need to know is this normal operating temperature for my car? thanks for the help.
Old Mar 29, 2004 | 08:29 PM
Irocvette355's Avatar
195* is the operating temp.
Fans kick on at 227* with the stock fan switch
(if you have electric ones)
Old Mar 30, 2004 | 10:18 AM
hey thanks for the reply. 190 range is probly where that is on the mark between 100 and 220, right?
Old Mar 30, 2004 | 02:16 PM
Originally posted by robvas
Do you have the black plastic piece that goes under your radiator? That plays a big part of keeping your engine cool while you're moving.
Yeah, that part is critical.
Old Mar 30, 2004 | 06:48 PM
Rice Killer87's Avatar
u guys arent reading the original post...
the line between 100 and 220 is about 180 or so i think,so its fine to run there. and yes,its fine for ur engine.
hope that helps
Old Mar 30, 2004 | 08:35 PM
hope that helps
thanks. i didnt want to say anything and sound ignorant, but thanks anyways to those that posted!
MikeWhitener
Aug 2, 2015 06:17 PM
4586
Jul 31, 2015 06:03 PM
Boss002
Jul 9, 2015 03:33 PM
Jmj93z28
Jul 8, 2015 10:01 PM
surreybrad
Jul 5, 2015 10:36 PM
