those with miniram?
Old Apr 8, 2004 | 11:15 PM
kandied91z's Avatar
those with miniram?
what are you using for your thermostat housing? i'm having problems with mine not working right and would like to know if i have any options.....almost wish i could do a remote thermostat that was located off the intake since that area is so limited for me.
Old Apr 9, 2004 | 08:47 AM
onefastgta's Avatar
Cut it off and get it welded, tpis is a bunch of dorks, they will tell you the same thing if you ask them why it doesn't fit.
They will also charge you for cutting and welding something that is supposed to fit already.
Old Apr 9, 2004 | 01:48 PM
kandied91z's Avatar
not sure i'm following you? the worst part about my particular instance is the housing itself has the grooves that hold the thermostat rather then the base of the intake itself so in theory you have to be able to get it to sit properly while installing the housing rather then just placing the thermostat onto the intake followed by the housing....
because of this design it makes it very difficult to get it to seal right.
TPIS is a waste of money but i'm stuck with the part now so i need to make it work.
Old Apr 9, 2004 | 03:01 PM
onefastgta's Avatar
The water neck on the thermostat housing points straight at the serpentine belt, making it impossible to run the belt with the radiator hose attached.
I've never had a problem with it leaking, but I use rtv instead of the gasket.
Old Apr 9, 2004 | 07:40 PM
TheGreatJ's Avatar
Use a piece of string looped through the bridge of the 'stat to hold it against the housing, then just pull it through once the housing is tight.
Old Apr 10, 2004 | 02:54 AM
kandied91z's Avatar
that's a good idea, simple but to the point...i'll have to try it.
MaxLean
Advanced Tech
Jun 9, 2006 08:15 PM
FastZinTennessee
Jan 31, 2006 07:20 PM
kandied91z
Aug 27, 2004 08:40 AM
chriswtx
Aug 2, 2004 11:44 PM
91B4C
13
Jul 15, 2004 08:42 PM
