drop in replacement engine for 92 rs camaro
Old Mar 30, 2004 | 10:03 PM
benbkansas's Avatar
Hi guys Iwas just wondering what i could replace my factory 305 in my 92 camaro with would like to find a drop in repacement but would like to get a vorteck or lt1 motor is that possible? thanks ben
Old Mar 30, 2004 | 10:10 PM
Ville H. Valo's Avatar
lt1
Old Mar 30, 2004 | 11:17 PM
AutoRoc's Avatar
Anything is possible with these cars. Money, Time, and Talent are some of the limiting factors.
A Carb Vortec engine swap would be easiest and possibly the best bang for the buck but an LT1 swap would reward you with much better fuel mileage($$$$ back in your pocket) and good power to start with. Increasing power in both applictations is easy with the aftermarket avaliable online or through local speed shops.
I personally would save up the funds and do some homework and do an LS1 engine swap. Find a used engine and tranny+ computer, wiring, etc... A cam swap for sure, something a bit "hotter" 11's All motor, cam only Reliability, killer gas mileage, and smooth strong power all in a sweet little package. Don't be suprized if you see me do this instead of a HUGE 600+ cube big block in the future www.thirdgenresource.com has a LOT of the parts to complete the swap. Goodluck!
Oh and wise man says budget accordingly. Then triple it to save yourself headache and time while in the middle of the whole ordeal...or something like that.
Old Mar 30, 2004 | 11:23 PM
PyRo9862's Avatar
350tbi (L05) from a caprice. Almost everything should bolt right up, you need to change the knock sensor and one other things that I cannot recall. You will also need to do chip tuning. Its as close to a bolt it as you will ever get though.
Old Mar 31, 2004 | 02:12 AM
dj haf's Avatar
lt1 can be done, but it's something i wouldn't want to do. too much of a hassle.
Old Mar 31, 2004 | 10:57 AM
aklim's Avatar
For too little gain. I would go with a built fuel injected setup. Say AFR heads with the Superram intake or HSR intake if you don't need to pass emmissions.
nballisru
Dec 14, 2014 05:01 PM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
ChrisFrez
Nov 23, 2014 10:33 AM
Snoman73
Nov 17, 2014 07:22 PM
