Fan Switch / Knock Sensor Wires
Old Apr 11, 2004 | 12:47 AM
shwine617's Avatar
I put a hypertech fan switch in the rear passenger side cylinder head and it's not working. It's the 200 on 185 off and the car still runs at 220. I have a blue and a gray wire coming out of the wiring harness toward that direction. The blue wire goes to the knock sensor and the gray one goes to the fan switch. I just wanted to know if the wires are in the right place. Is there any way to test it with a volt meter ot test light, or just any other way to find out why it isn't working. The A/C is out of my car if that makes a difference.
thanks. Also which fan does the switch turn on the passenger or drivers one.
thanks for all the help!
Old Apr 11, 2004 | 01:00 PM
aklim's Avatar
If you have them crossed, I believe the ECM will trip a code.
Dark blue is the KS wire according to Chilton.
Old Apr 11, 2004 | 11:02 PM
shwine617's Avatar
do you know why it may not be working?
Old Apr 12, 2004 | 12:17 AM
aklim's Avatar
Not a clue. Bad wiring, bad relay, bad fan maybe. Take the wire going to the switch and ground it and see if the either fan comes on.
HectorM52
Jul 30, 2017 11:46 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
