questions about my 700r4
Old Mar 25, 2004 | 09:52 PM
lordmetalz28's Avatar
so my camaro is set for the rear rebuild this upcoming wensday.well i had a run in with my tv cable and trying to adjust it etc etc lets just say i had to drive/adjust drive/adjust the way they say how to adjust it just wouldnt work on my car who knows why so i got it adjusted deciently. check this out. at like a light cruise ill shift gears smoothly around 2500rpm. when i beat on it i usually shift at like first to second around 3500rpm possibly 4000rpm. and i havent had enough road to get her to 4th so far. usually doing about 80mph in third while beating on her. then i have to let off so i can slow down and make the turn. but do these shift points look normal or am i still a little mis adjusted my car info is below. thanks
Old Mar 26, 2004 | 02:26 PM
Z28James's Avatar
When my car was out of adjustment, it would jump some RPMS before it would shift..or wait a REALLY long time (4000RPMS) to shift even when cruising. Now she shifts between 2500-3500 and when i romp on it, about the same as you...it will shift into 3rd around 75-80mph.
Old Mar 26, 2004 | 05:11 PM
sounds like im pretty much thier. yeah when i first touched it she wouldnt get out of first till 5000rpm and that was going slow. but on a worse note got my rear stuff today and those basterds didnt ship me my ring and pinion bolts looks like im screwed unless they keep thier word an over night it.
Old Mar 28, 2004 | 06:32 AM
Z28James's Avatar
Geez that sucks man. id be pretty dissapointed too. Im glad you got your tranny TV cable set right thought, that thing is such a pain.
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
