"VATS"
Old May 25, 2005 | 06:25 PM
89_Irocz's Avatar
Unhappy "VATS"
Does anyone now where the "VATS" control box is located in a 89 iroc-z.... I have to change steering columns with one out of a donor car... Instead of changing the ing. switch to make in work with my car, I was going to change the VATS control box...
Old May 26, 2005 | 08:41 PM
masiroc566's Avatar
Re: "VATS"
tyr this site...http://www.thirdgen.org/newdesign/tech/vats.shtml...
Old May 27, 2005 | 03:06 AM
NC 91 Z28's Avatar
Post Re: "VATS"
I just finished changing the VATS box on my 91 and it was a pain in the a**! It’s on the passenger side on the firewall under the dash by the heater core. It’s very hard to get to, I found that if you unbolt the entire dash and steering column the dash assembly will slide foward and you can reach back there and unbolt it easily.
Old May 27, 2005 | 08:47 PM
89_Irocz's Avatar
Re: "VATS"
Thanks!!!!!!!!!!!!
