Strange vs Motive Rear Gears, also which ratio:
Old Apr 28, 2005 | 05:30 AM
DTL504's Avatar
I'm about to buy a Strange 12 Bolt Rearend for my 84 Camaro. I need help on decieding which would be the best gears (Strange or Motive) and what gear ratio should I go with?
I have tried the online calculators and still is confuse whats best for my car, so im going to rely on ya'll experince and professionalism to guide me in the right direction. I was thinking the 3:73, but has considered the 4:11
Here is the combo:
My SBC 409
Engine Block: 400 SBC ID# 330817/14y139664/ T0508CSU
(4.125 bore X 3.750 stroke) after .040 bore (4.165 bore x 3.75 stroke =409)
Deck Plate Bored, Mains Align Honed, Block Deck .002, Deck Plug Holes & Tap w/3/16 Holes, Starter Bolt Drilled, Front Three Gallery Plugs Tap for ¼ Pipe Plugs.
Crank: Scat 4340 Crank 3.750 6.00, Internally Balance, Part# 4-400-3750-6000
Bearing: Clevite– MS1038H Mains and CB663H Rods
Piston: Wiseco Pistons, .040 over, 5.4cc; 430 grams, Part# PT020H4
Rods: Eagle ESP 4340 H-Rods 6.0, Part# CRS6000B3D
Block: Deck: 0.002
Compression Ratio: Static-10:44 Dynamic-8:27
Cam: Grind: Solid Lunati
280/284F10 .525/.530 Lift, 247/251@.050, 159/162 at .200, .500/ 504 valve lift, 2500-7000 RPM, Installed Straight up, .026" Valve Lash Hot, .022
Valve Springs: Lunati Part#73124 130 Seat 330 Open.
Heads: AFR 195 Part# 1035 w/23º valve angle, 74cc, drilled steam holes.
Head Gasket: Fel-Pro-1014 / .039 in. compressed thickness, 4.200 in. bore, 9.0 cc compressed volume
Intake: Edelbrock RPM #7101
Carb: Speed Demon 750 Mechnical
Rear End Gear: 3:73
Transmission: Pro-Built Street/Strip 700R4
Stall Converter: A.C.T. 3000 Stall
Exhaust:
Hooker Super Comp headers 1 5/8 Headers part # 2460-1 ceramic coated;
Hooker Super Competition high flow cat-back exhaust system, Intermediate pipe: 3 in.
* Tail pipe diameter: 2 1/2 in.
* Dual tail pipes out the rear under the bumper
26" tall tires
Weight: 3400lbs
Old Apr 28, 2005 | 09:27 PM
85_305's Avatar
Re: Strange vs Motive Rear Gears, also which ratio:
What RPM band is your cam good for?
If the RPM band has your car making hp at 5k+, then get something like 3:23's. If your car is making optimal power below 5k, then go w/ something like 3:73's or 410's. Since you only have a 4spd tranny, I would go w/ the 373's as you will loose a LOT of wind up-top w/ 410's.
Just my opinion
EDIT: Just noticed your rpm-band next to your cam specs; I would DEFFENINTLY go with 373's to 323's.
Old Apr 28, 2005 | 10:00 PM
doug791's Avatar
is it stock 700 gearing?
and how big are your wheel/tires because that matters
With a 245/50/16, and 3.73's and shifting at around 5500 im having to shift into OD right about the 1/4 mile mark. Its been a while since ive driven the beast so i forget exactly what speed im at when shifting into OD.
Generally 3.73's with the 700 are considered a bit overkill so i doubt youd want to go bigger then that.
Old Apr 29, 2005 | 05:16 PM
85_305's Avatar
Ya, I was leaning towards the 3:23's, but left the 3:73's open as an option. Not a very wise one though...
Old Apr 29, 2005 | 05:23 PM
doug791's Avatar
you have to remember this is a 400 small block that could easily be pulling to 7000 rpms. I still think 4.11's would definitly definitly be overkill. If its a stupidly high powerband maybe youd want 4.11's to get you out of the hole. Also depends is this a drag car where you want to be topping out 3rd right as you cross the 1/4? or is streetability more important.
If you want that expert advice try www.thirdgen.org/techbb2
Old Apr 29, 2005 | 05:29 PM
85_305's Avatar
400's pull high rpm's?? I never knew that...
But here is this dudes cam specs:
That is why I am recomending the 3:23's or 3:73's. And even 411's if you wanna top out at 120 or so
Old Apr 29, 2005 | 05:32 PM
doug791's Avatar
any motor pulls whatever you want it to. All depends on what cam intake heads hes using and i didnt really pay any attention to the motor cause other then powerband it doesnt matter.
If youre going to be shifting at 6500 3.73's are the way to go, with my 350 the 3.73's i have to **** into OD right at the end of the 1/4 so if youre gonna pull a bit higher rpms they should be just fine. You dont need 4.11's with a 700
Old Apr 29, 2005 | 06:19 PM
DTL504's Avatar
Thanks for all the input, today I ordered in a group purchase my Strange w/ Super Posi rearend with the 3:73 gears.
You can look at my dyno sheets to see how the engine pulled throughout the RPM range. 6500 and still going.....
http://community.webshots.com/user/dtl504
Plus I still have to do some more tuning, so a little more power will be revealed..
Old Apr 29, 2005 | 10:43 PM
85_305's Avatar
Wow man, those are some GREAT numbers
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
redz_02
Jul 24, 2002 09:42 AM
