Fan... and overheating...
Old May 18, 2005 | 03:03 PM
BlackHawkA4's Avatar
My fan dosn't seem to be turning on. I orignally check this and it was turning on when i initialy turned the car on. I checked this because my engine temp is getting 220 plus in stop and go traffic. So now I'm looking at it and it dosn't turn on. And now I'm seeing a leak, which was smoking when I opened the hood to see if my fan was working, whatever was leaking was ontop of the right manifold cover.
Old May 18, 2005 | 03:18 PM
masiroc566's Avatar
Re: Fan... and overheating...
Check your fuses first!!
Old May 18, 2005 | 03:24 PM
The fan turns on when I put the AC on. It just dosnt turn on or stay on when driving.
Old May 20, 2005 | 06:24 PM
89_Irocz's Avatar
On the right Head above the starter, is the Fan switch. It is a little sensor that when the engine reaches 220, It grounds the fan to the engine witch turns on your fan. It's only about $10. If bad or broken it "CAN" leak Good luck!!!
RaTeD SHocKeR
Oct 13, 2010 05:16 PM
BoobSter-lt1-z
Jul 9, 2007 11:04 PM
Drowned
Apr 8, 2006 12:42 PM
dtp
Aug 12, 2005 08:31 PM
Klypto
Sep 27, 2004 01:50 AM
