So besides a 305, What else fits a 700R4 Trans?
Old May 14, 2005 | 02:02 PM
YARDofSTUF's Avatar
Are there other options?
Old May 14, 2005 | 02:08 PM
TBI_InYourEye's Avatar
Re: So besides a 305, What else fits a 700R4 Trans?
I thought all 3rd gen engines were hooked up to the 700R4. Everything from the 2.8 to the 5.7. There was a 3 speed auto in early 3rd gens, but I'm pretty sure the majority of 3rd gens with autos were 700r4s.
Old May 14, 2005 | 02:16 PM
YARDofSTUF's Avatar
Thats conveinent(sp) Thanks
Old May 14, 2005 | 02:27 PM
doug791's Avatar
the 700 is the tranny, and GM uses it in everything. They are common in trucks, and the 4th gen camaros use a 4l60E which is basically the exact same thing as the 700
Old May 14, 2005 | 06:15 PM
DevilsAddvocate's Avatar
Any Gen 1 sbc, bbc im guessin you can to but need the right flexplate so it fits in the bellhousing (if im wrong somebody correct me)
Old May 14, 2005 | 10:10 PM
92RS305#2's Avatar
any gen I SBC and the LT1 for Gen II i know at least can go also. as far as big blocks i dunno.
Old May 15, 2005 | 01:59 AM
Zepher's Avatar
The 3.1 and 2.8 700R4's and the 3.8 4L60E don't bolt up to a SBC. different bellhousing pattern.
LS1 tranny's don't bolt up anything besides a GenIII block.
The 4.3 V6 uses the sbc bellhousing pattern, so tranny's from those will work on any sbc or LT1.
The flexplate you use is determined by the rear seal type of the engine, the starter type, and the type of tranny. Torque Converter has to match the tranny and the flexplate.
Old May 15, 2005 | 03:51 PM
Black305RS's Avatar
anything engine can fit on any trans you just need to have the right conversion kit
Old May 24, 2005 | 09:04 PM
92LT1RS's Avatar
obviously they were talking about combinations that don't need a bellhousing adapter
Old May 24, 2005 | 10:36 PM
82355's Avatar
Well technically you can bolt a BOP pattern transmission upto a small block Chevy too. Downside is only two bolts line up. I don't think any 3.8s were ever mated to a 3.8 from the factory though. They came bolted to Th2004Rs.
Martin
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
bossco
Nov 29, 2014 10:18 AM
