Offset/Drop base air cleaner?
Old Jun 21, 2005 | 12:00 PM
Tru2Chevy's Avatar
Do any of you guys know where I can find an air cleaner that is offset for a largecap HEI and also has a dropped base to clear the stock hood? Preferably a 14x3. Also needs to clear an electric choke Q-jet.
I have tried one that is just a drop base, but that rubs the distributor, and I have tried just an offset, but that barely touches the hood bracing. I am going to take the center hood bracing out anyway, but this motor shakes a bit
Any ideas/suggestions?
- Justin
Old Jun 22, 2005 | 11:58 AM
Tru2Chevy's Avatar
Re: Offset/Drop base air cleaner?
No one? I know I can't be the only one here who runs a largecap HEI and still has a stock hood....
- Justin
Old Jun 22, 2005 | 12:16 PM
Z28SORR's Avatar
To stop the engine shake get some poly or solid engine mounts. Most people don't like solid mounts.
It sound like your trying to get 10lbs. in a 5lb. sack. Get a raised hood or a smaller cleaner or a different designed cleaner.
Most people that I know that run 14" cleaners use a spacer under the carb. which requires a cowl hood.
Old Jun 22, 2005 | 12:53 PM
Tru2Chevy's Avatar
Poly mounts are planned for the future, but for now I'm stuck with brand new rubber ones. Can't afford a cowl, and would rather not have one anyway.
I found a K&N offset aircleaner that uses a 2 5/16" tall element. I'm thinking that combined with the bracing removed from the center of the hood might work, but it's $80.
What other type of cleaner would clear the hood?
- Justin
Old Jun 22, 2005 | 03:48 PM
angel71rs's Avatar
Summit carries no name offset air cleaners. Substitute 432 for 3", 442 for 4":
http://store.summitracing.com/defaul...=KeywordSearch
Old Jun 23, 2005 | 09:39 AM
Tru2Chevy's Avatar
Thanks, I didn't see those when I was browsing Summit. I don't know if a 14x2 is enough to feed my 400, but I guess it's better than the stock one....
- Justin
Old Jun 23, 2005 | 11:00 AM
Z28SORR's Avatar
You could get one of these tops also.: http://store.summitracing.com/defaul...2&autoview=sku
Fatdog2
Feb 13, 2015 08:19 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
stanghunter211
Aug 29, 2002 03:04 AM
