low 13's?
Old May 13, 2005 | 10:13 AM
chevypwr6's Avatar
Question low 13's?
hey guys,
im lookin to get a late model third gen within the next few months, gonna be TPI, not sure its its gonna be a 305 or 350 (whatever i can find really...preferably 350 tho ) i want the car runnin low 13's (13.2-13.4) what are some mods i can do to accomplise this?
Old May 13, 2005 | 01:01 PM
teke184's Avatar
Re: low 13's?
ram air
port the intake Y
52mm tb
port the hell out of the plenum
full tune up with new distributer
headers and exhaust
mild cam
custom chip
and suspension mods to hook that torque to the ground
been out of the TPI area for a while...maybe without the cam you could make low 13s...but it'd be hard
Old May 13, 2005 | 01:16 PM
V8 Slayer's Avatar
Re: low 13's?
13's with a 350 TPI is not that hard
Full Exhaust-Headers,High Flow Cat,3 inch Catback
Cold Air Intake/Air Foil
Underdrive Pulleys
Be in good tune.
Old May 13, 2005 | 01:55 PM
chevypwr6's Avatar
Re: low 13's?
thanks guys appreciate the help
Old May 14, 2005 | 08:54 PM
85_305's Avatar
Re: low 13's?
Originally Posted by chevypwr6
hey guys,
Whats wrong with the 305 TPI? They ran just as fast, infact a bit faster, than it's 350 counter-part
But like V8 Slayer said, 13's w/ the 305 or 350 TPI is NOT a difficult task
Old May 14, 2005 | 10:37 PM
V8Rumble's Avatar
Re: low 13's?
Old May 15, 2005 | 01:05 AM
doug791's Avatar
Re: low 13's?
Its amazing how you can say things that are just blatently not true.
The 305 is not easy to get into low 13's, youd be talking new intake, cam, full exhaust, and probably new heads.
A 350 would even need some work to get into the low 13's with rear end gears, full exhaust, and mildly ported heads i expect my car to run a high 13.
So with a cam and some intake porting im hoping to run a 12.99, possibly get the heads ported more previous owner had that done and ive never seen the job that was done on them.
Also know if youre going for a 13 flat youre probably gonna blow out your tranny and rear end, so be prepared to replace those
Old May 15, 2005 | 12:49 PM
chevypwr6's Avatar
Re: low 13's?
Really?!?!?
the stock tranny and rear are that bad in these things? man...every second im leaning closer and closer to a late model 4th gen.
Old May 15, 2005 | 01:10 PM
Wpns Grd Plutonium's Avatar
Re: low 13's?
Really?!?!?
4th Gen rear ends aren't much better.
Old May 15, 2005 | 03:01 PM
Marc 85Z28's Avatar
Re: low 13's?
Want low 13's? Want TPI? Without a LOT of bolt-ons, gears, converter etc it wont happen. That's where a blower or nitrous comes in.
And the rears and automatic transmissions in the 4th gens are no stronger than the 3rd gens. It's just the 4th gens components are generally much newer. Some 3rd gens even came with a 9 bolt rear, which is a good bit stronger than anything ever offered in the 4th gen cars.
Old May 15, 2005 | 04:30 PM
85_305's Avatar
Re: low 13's?
Really? I blatently say things not true?
How is putting in a new cam and getting a full exhaust, and putting a new intake on hard?? You dont need aftermarket heads on your 305, just get them machined if you have a friend in the business..
But that honestly does not sound like a "lot" of work to me.
Old May 15, 2005 | 04:33 PM
85_305's Avatar
Re: low 13's?
Originally Posted by V8Rumble
Why is that funny? The 305 standards were just as fast as the 350 auto's.
Old May 15, 2005 | 04:48 PM
Marc 85Z28's Avatar
Re: low 13's?
Maybe if you compared a late SD G92 305 to say an early 87-88 350, especially a GTA. But even the strongest 305 could not keep up with the 90-92 350 cars.
Old May 15, 2005 | 05:36 PM
CustomSSI's Avatar
Re: low 13's?
To get low 13's out of a TPI your gonna need the following...
First off ported TPI system, different runners and ported intake base. SLP 1 3/4 headers full exhaust and good tune. Also if you car is an automatic a good 2500rpm-3000rpm stall would do wonders. Then if you can porte your heads and 1.6 rr's should get you around where your wanting to go. We did a GTA one time and got it to run 13.8 with just ported heads, ported TPI, SLP runners cat-back exhaust and good tune. The customer claimed to keep up/take stock LT1's rather frequently, so theres some suggestions for you.
Josh
Old May 15, 2005 | 05:48 PM
85_305's Avatar
Re: low 13's?
I have been told that due to the higher parasitic loss thru the auto, and the slightly heavier weight, the auto 350's (TPI) were very evenly matched by the standard 305 TPI's.
