Run on
Old May 12, 2005 | 08:47 PM
chevy87z28's Avatar
Run on
So far in two instances, both when coolant leaked out of a hose, my car has experienced run- on as in when i took the key out it didnt stop and i had to resort to poping it into first and stalling it out. Any advice on what this means or why it happend would be great. Thank you
Old May 12, 2005 | 11:51 PM
krow's Avatar
Re: Run on
WOW! Thats the first time I have ever heard of that happening. Anyways it sounds like you have a problem in the igintion switch, or igintion module. Hope this helps
Old May 13, 2005 | 06:53 PM
Phantomfe3's Avatar
Re: Run on
once in a while my car does this, like if i turn it off the will sputter and fire once or twice more, but it wont stay actually running
Old May 13, 2005 | 08:50 PM
91-Z28-L98's Avatar
Re: Run on
If it stays running smooth, then its definately a problem in the ignition switch or some kind of wiring to the ignition. If it stays running for a few seconds but is rough, the problem is probably leaky injectors.
Old May 15, 2005 | 10:21 AM
respectirocz's Avatar
Re: Run on
is it even fuel injected?
usually with fuel injection when u turnoff the key it shuts off ignition as well as fuel injectors, but if u have a bad ignition module, or ignition switch then everything could still be running
when a car continues to run after being shut off, and it sputters the whole time is called dieseling, because u dont have spark but it still ignites on compression, just like a diesel engine, but it only happens on a few cylinders
its usually caused by excessive heat, or high compression/low octane gas,
thats about as much as i can help
Old May 15, 2005 | 03:07 PM
Marc 85Z28's Avatar
Re: Run on
Carbed motor right? Do you remember what your idle RPM was when shutting off? Run-on/dieseling is most often caused by too much RPM. If you're RPM is higher than 800 in park/neutral, look for either a maladjusted carb, a choke problem, or a vacuum leak. If it still does it when the RPM is set to the underhood sticker, check ignition components and engine temperature. Most likely you'll find a choke problem, as is quite common with older neglected QJets.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
