Planning an LT1 swap into my 86 Z28
From: Natchitoches, The Free State of Northern Louisiana
I have a couple of things I need ironed out.
1.My car is carb equiped, where can I get the TPI tank-to-engine hard lines I need to convert to FI
2.I'm aiming for a 95-96 corvette engine (maybe an LT4
) because of the way the vette AC pump mounts. Will I be able to reuse my stock AC lines? (the vette ac pump mounts in almost the same relative position as my 305)
3.I've heard you have to swap a 4th gen radiator. Does it bolt in place of the stock 3rd gen radiator.
4. will I have to get custom PS pump lines made?
5.What ECM would you guys suggest, 92-93 speed density MPI or 94 MAF SFI?
) because of the way the vette AC pump mounts. Will I be able to reuse my stock AC lines? (the vette ac pump mounts in almost the same relative position as my 305)3.I've heard you have to swap a 4th gen radiator. Does it bolt in place of the stock 3rd gen radiator.
Brandon Wittmer
Dec 7, 2014 12:15 PM
Jul 4, 2005 05:00 PM
