alternator wires?
Old Jun 8, 2005 | 03:47 PM
joejoe's Avatar
alternator wires?
I have an 86 IROC that has a 2-wire alt. I changed to a 91 set/up, the 91 has a 3-wire alt. I need to know how to go from a 2-wire to a 3-wire plug.
thanks, joe
Old Jun 9, 2005 | 11:57 AM
respectirocz's Avatar
Re: alternator wires?
can u use the old alt just swap he pulleys or are the mounting brackets different?
Old Jun 9, 2005 | 07:17 PM
joejoe's Avatar
the way it mounts is totaly different.
Old Jun 11, 2005 | 09:16 PM
BOTTLEDZ28's Avatar
the 3 wires on the 91 style alternator are as follows:
RED(or black)---goes to battery+
RED-------goes to starter
brown---goes to Fan fuse in fuel panel.
the alternator grounds itself by the case once you mount it
I do not know how the wires are on your cars factory setup.
I remember seeing an adapter harness for this setup on the net somewhere
Old Jun 13, 2005 | 05:16 PM
joejoe's Avatar
thank you for info. my factory alt. has a red, and green wire, and a bigger red wire that went from back of alt. to bat. I will look for an adaptor for this app. thanks, joe
Old Jun 13, 2005 | 07:53 PM
BOTTLEDZ28's Avatar
if you cant get the wiring straightened out, then try to see if you can swap out the guts from one to the other.
eanhl2004
Apr 4, 2015 12:01 PM
Red97LT1
Mar 1, 2015 05:08 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
