L98 with a manual tranny
Old Jun 14, 2005 | 02:31 PM
Slow91z's Avatar
Hey fellas I have a question...I'm about to put a 87 L98 into my buddies 92 5 speed RS...I was just sitting here thinking and way back when I seem to remember someone sayng L98's don't have a hole for the pilot bushing since none of them came with manuals.
So my Questions to you are
1. Is my memory clear, or did I smoke to much as a Teenager
2. Will the crank out of the 305 that's in the RS work in the 350?? I know they are the same stroke, but I do not know if they are the same bearing clearances or if it's as strong.
Old Jun 14, 2005 | 11:45 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: L98 with a manual tranny
There is no reason why you cannot put a pilot bearing into a 350 crank. The hole for it is there on all cranks.
Old Jun 15, 2005 | 07:50 PM
iansane's Avatar
Doooo eeeet.
The pilot bushing, not the crank.
Old Jun 15, 2005 | 08:09 PM
mako350Z28's Avatar
You are gonna destroy that 5-speed. I would see if I could find a T-56 if I were you guys.
Old Jun 15, 2005 | 09:19 PM
iansane's Avatar
Do you have a 350/5speed combo?
Old Jun 15, 2005 | 09:49 PM
mako350Z28's Avatar
No, but why do you think all of the 350's came with an auto? The 5-speeds can't handle the torque from the 350.
Old Jun 15, 2005 | 10:35 PM
cc89formula's Avatar
if you get lucky it will
Old Jun 16, 2005 | 12:13 AM
Slow91z's Avatar
We plan on destroying it...That way he has a reason to upgrade it :-)
Na it's a work in progress and it's a second vehicle so if he breaks it no biggy...Don't know what he'll go with later.
Thanks for the input fellas, musta been smoking a buncha weed back then.
Old Jun 16, 2005 | 08:56 PM
Kevin91Z's Avatar
My T5 lasted behind the combo in my sig for almost a year, including the 12.80 run, but the next trip to the track, it shredded third gear. A T5 will handle a 350 engine just fine on the street. The problem is when you bolt on sticky tires and go racing.
Old Jun 16, 2005 | 08:59 PM
Slow91z's Avatar
Well yeah, but we're gonna abuse it.
Old Jun 17, 2005 | 02:22 AM
iansane's Avatar
You must believe in Santa Clause too, right? There are plenty of people out there abusing t5's. Stock for stock 305 vs 350 there was only 15-20 lb/ft difference.
Old Jun 17, 2005 | 01:21 PM
mako350Z28's Avatar
For an '87 maybe. For my year Z28, it was anywhere from 45-60 ft-lbs.
Pardon me, it was 35 ft-lbs for an '87.
Old Jun 17, 2005 | 01:30 PM
mako350Z28's Avatar
And just for the record, I took out a t5 with a '91 RS 305 tbi STOCK.
Old Jun 17, 2005 | 02:28 PM
Rottluver's Avatar
T-56's can break too.......almost nothing is bulletproof.
Old Jun 17, 2005 | 03:12 PM
mako350Z28's Avatar
I know that. I was just making a point.
