My Serpentine belt keeps splitting
Old May 31, 2005 | 06:49 AM
86305Z28's Avatar
yea just like the title says my serpentine belt keeps splittin in the middle. gettin a bit annoying now since this will be my 3rd or 4th this year
what cud be causing this? do i have to replace a certain pulley or should i replace them all?
thanks for any help given
Old May 31, 2005 | 11:33 AM
Rice Killer87's Avatar
Re: My Serpentine belt keeps splitting
Try taking the belt off and looking and spining all the pullies. Sounds like theres something on one of the pullies cutting it or making a mark in the belt and causing it to split.
Old May 31, 2005 | 11:38 AM
krazzycowgirl's Avatar
Also run your hand around the pullys to see if it might cut you, if it does Change pullyies.
Also where you buying your belts at? I will not buy belts at Shucks no matter if they are slightly cheaper then anywhere else. They have a problems with splitting as well.
Old May 31, 2005 | 12:54 PM
86305Z28's Avatar
yea i dont cheap out with my car. i get the best belts i can get. ill take a look at the pullies when i get back home.
since ill probably need new ones can someone recommend me good pullies for a 89 Camaro RS w/air conditioning, no smog pump, V6 2.8L
thanks for the help again
Old May 31, 2005 | 01:15 PM
ChicagoTransAm's Avatar
Also make sure your brackets are in good shape....not sure how the serpentines work (I have an 85 with V-Belts) but the alternator bracket bolts to the runners and had somehow gotten bent a little causing belt slippage and breaking.
Old May 31, 2005 | 02:19 PM
86305Z28's Avatar
alright thanks ill make sure of that
Old May 31, 2005 | 04:25 PM
ZFan88's Avatar
If you don't feel like possibly cutting your hands up, take a cloth and run it around the pullies. Much easier, plus will catch the smaller things.
Old Jun 1, 2005 | 01:19 AM
hey no pain no gain right lol.
Yea the cloth Idea is better then cutting up ya hands.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
