smoking
Old Jun 22, 2005 | 07:21 PM
erik02's Avatar
smoking
when i first turn on my car it smokes, its has been doin this ever since i parked it on my grass after driving it , my friend says that its prolly water moisture but im doubting that can anyone tell me what it is, also its white smoke.
Old Jun 22, 2005 | 07:55 PM
chevyz28racer's Avatar
Re: smoking
white smoke... hmmm well blue is usually oil i.e bad valve seals...... black is usually fuel releated *running rich*... am i correct?
Old Jun 22, 2005 | 08:00 PM
'86 350's Avatar
Re: smoking
You are correct. White smoke is usually a sign that your burning coolant or water. However, I believe cars that burn coolant do it all the time, not just on start-up. I'm not positive though.
Old Jun 22, 2005 | 08:24 PM
erik02's Avatar
Re: smoking
so far from wat i know it only does it when it starts but im not positve, i will find out next time i drive it (dont have my license, just trying to get car ready for when i get license next month)
Old Jun 22, 2005 | 08:40 PM
Dave89IROC's Avatar
Re: smoking
i've seen really light colored smoke(white or light grey) from oil(valve seals)
Old Jun 23, 2005 | 12:05 AM
Runin2Nite's Avatar
Re: smoking
how long does it burn white check your oil and your coolant if they seemed to be mixed u gots some work ahead of u.
Old Jun 23, 2005 | 09:17 AM
erik02's Avatar
Re: smoking
i dont belive that they are mixed because they dont look like a milkshake,from wat ive heard thats what it would look like, it only smokes for a little while after i start the car
Old Jun 23, 2005 | 08:16 PM
Oddball's Avatar
Re: smoking
I've had the same issue with my LG4. The black smoke on startup was me pumping too much fual before starting. The white smoke was moisture in the engine / enhaust from sitting on grass and the early morning dew. If you don;t get the white smoke in the afternoon when the morning moisture has burned off it is probably just morning dew.
Old Jun 28, 2005 | 01:37 PM
fade2blk500's Avatar
Re: smoking
I vote that the smoke is from oil and that it's valve seals. Not really too big of a deal. Technically it could run forever like that. But if you do fix it, swap the cam and springs while your down there
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
