92 305 TBI to TPI swap
What all is needed to do this swap??
Also to complicate the matter we're thinking about using an older 2 pcs. rear main 355 with trickflow heads and a healthy cam, and a holley stealth ram intake.
Do the TBI and TPI car's use the same computer?? Do we need a TPI ECM or will a chip change work?? What about the harness?? any sensors interchange between the TPI and TBI??
Thanks for any and all help fellas, this is going in a 5 speed car also just to let you know.
Re: 92 305 TBI to TPI swap
im doing this now
instead of listing it all here go to www.thirdgen.org in the tech articles theres an article on this.
its quite a bit but its doable
Originally Posted by Black305RS
im doing this now
Any other input will be welcomed.
