Spark plug gap
Old Jun 22, 2005 | 01:01 PM
'86 350's Avatar
Spark plug gap
I just bought an '86 Camaro, and I replaced the plugs in them. Only thing is I need to know the gap on the plugs. It's not the stock engine though, it's an aftermarket 350 crate engine. Does anyone know about what I should set the gap to? Thanks.
Old Jun 22, 2005 | 01:11 PM
Tru2Chevy's Avatar
Re: Spark plug gap
Give us the basic specs of the motor and ignition system, and we'll give you an idea of where to gap the plugs. If its stock ignition and a relatively mild motor, .035 or .040 is prolly your best bet.
- Justin
Old Jun 22, 2005 | 01:16 PM
'86 350's Avatar
Re: Spark plug gap
Okay-
350 short block with 2.02 heads
High lift cam- not positive on the powerrange exactly
Edelbrock intake and Holley 670cfm Street Avenger carb
Putting out an estimated 350hp 350 lb. ft. of torque at the crank
Edelbrock headers
Not positive on the ignition system, the top of the distributor says "Carburetor shop" on it. That's it.
I'm using Moroso Blue Max spiral core wires.
Do you need anything else?
Old Jun 22, 2005 | 01:31 PM
Tru2Chevy's Avatar
Re: Spark plug gap
Well, since you don't know much about the ignition I would stick with .040" - a small gap will cost you a touch of power, but it's better to be a little too small than a little too big.
I have a largecap HEI with a recurve kit, accel coil and 8mm accel wires, and I'm running a .045" on the car in my sig. Haven't really tested it yet to see how well it's working out since the car isn't quite road-worthy yet.
- Justin
Old Jun 22, 2005 | 01:50 PM
'86 350's Avatar
Re: Spark plug gap
Okay, thank you very much. Will the motor give any signs if I have the gap to large?
Old Dec 2, 2005 | 05:10 PM
'86 350's Avatar
Re: Spark plug gap
Hi, I'm bringing this thread back because I bought new plugs. I bought Accel 576S plugs and new BlueMax spiral core wires. Do you guys think my gap should be about .040?
Old Dec 2, 2005 | 06:34 PM
1987IROC350's Avatar
Re: Spark plug gap
I just bought a crate 350 and got the new Diamond Fire E3 spark plugs. They dont need to be gapped. They sell them at summitracing.com. They are similar to Splitfire but go all the way around.
Old Dec 2, 2005 | 06:39 PM
anthony714's Avatar
Re: Spark plug gap
well with a high powered hei .050 isnt out of the ?,bigger the better,if its too big your going to notice a misfire and possibly a back fire situation.too small harder to tell.it will run but power will be down..040 -.050 with hei should be ok.try try try
Old Dec 2, 2005 | 06:51 PM
'86 350's Avatar
Re: Spark plug gap
Allright. I think I'll run .042 or .043 gap. Most likely I'll step up to .043. Thanks.
Old Dec 4, 2005 | 10:28 PM
coolram62's Avatar
Re: Spark plug gap
Spark gap is something to play with like timing,although more of a pain because of the R&R involved.According to Jacob's Electronics ignition book you start at what the factory baseline(which is a compromise at best)and increase by .005 till you feel the motor flatten out.Off the bat if you have a hotter coil,better wires,top of the line cap&rotor(which should always be used) you can open the gap .005 to .010.I'm running .050 in my Jimmy(she gets 21mpg on the hwy).
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
