Trouble Starting
Old May 22, 2005 | 11:02 AM
89_Irocz's Avatar
Angry Trouble Starting
I have a 350 tpi that is having trouble starting... I can spray starting fluid in the tpi and it will start fine and run fine. I will continue starting fine till it sits for a while (overnight), then it has trouble starting again.
Old May 22, 2005 | 09:51 PM
Runin2Nite's Avatar
Re: Trouble Starting
haveing trouble how....bogging out, not cranking hard, back fireing???
Old May 22, 2005 | 10:10 PM
89_Irocz's Avatar
Engine not getting enough gas to start... Turns over and trys to fire but won't. Spray starter fluid in the tpi and if fire right up and runs great..... Thanks
Old May 23, 2005 | 12:41 AM
thorguy57's Avatar
Sounds like a fuel pump relay. DO our cars have one? If you turn your key just to on you should hear the fuel pump kick on for a few seconds then shut off to presurize the fuel rail. If it doesn't you might have a bad relay. Will still start but takes a lot of cranking before it does. See quite a bit of chevys with this problem.
Old May 23, 2005 | 04:38 PM
89_Irocz's Avatar
You can hear the pump when you turn on the key
Old May 29, 2005 | 10:35 PM
camaroken's Avatar
do fuel pressure test. when running if it is in range remove the vaccum line from the pressure regulator. does it increase fuel pressure? if so regulator is good. if not in range suspect the pump. even though it runs whith a carb clean shot it may weak and not be able to keep its prime on its own.
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
David Dorris
Jan 17, 2015 08:10 PM
slothgrant
Aug 22, 2002 03:01 PM
