What injectors should I get?
Old May 5, 2005 | 03:15 PM
LoudmouthSS's Avatar
Well i have the stock ones on the car right now, but the guy who sold me it gave me a new fuel rail with an adjustable pressure reg. However he said 1 of the injectors is cracked on the tip, i checked it out and sure enough it is. They are aftermarket injectors, i belive 30 or 32's. anway can i buy just 1 injector from a company and with my modifications and future plans to run nitrous, what injector size would you guys suggest?
Old May 5, 2005 | 11:09 PM
Re: What injectors should I get?
Anybody?
Old May 6, 2005 | 10:55 AM
krazzycowgirl's Avatar
30lb fuel injecters unless heavly modded are stpuid. I found that out.
But I went with Ford Motorsports Injectors & 24#s at that.
Old May 7, 2005 | 02:38 PM
92BLKL98's Avatar
24# injectors are good up to about 350-375 hp on a properly tuned engine. Provided you program the correct parameters into your chip and your injector pulse width is not too short you can run 30#. I would not run more than 24# injectors unless you can program your own eprom. Go on TGO and look at TRAX's stuff on programming an learn, it can be interesting.
Old May 7, 2005 | 05:30 PM
Well i ordered 30 lbs. I stuck 350hp into a calculator and it said i needed like 27 or something, then i figure a 100 shot would get me to roughly 450, and it said 30's so i grabbed them....but neway I will be getting a custom programing for my car from diablo tuning around here
Old May 7, 2005 | 09:07 PM
92BLKL98's Avatar
With your proposed tuning and mods you'll do fine.
Old May 7, 2005 | 10:08 PM
alright sounds good thanks
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
