Throttle Body / Water Crossover Sensor......
Old Jun 12, 2005 | 06:07 PM
ZDADDY92's Avatar
What exactly does this water crossover sensor do which is located on the bottom of the throttle body? A feeder neck which portrudes from the sensor is in the way of my water neck, I was thinking of shaving off this feeder neck from the sensor, but it feeds into my intake and I am unsure if this feeds or returns coolant???? - I replaced my TPI with a TPIS mini-ram and it seems that it has a lower stance than the TPI. Also, what exactly are the benefits of a coolant bypass for a throttle body? Thanks in advance-
Old Jun 13, 2005 | 12:48 PM
Damon's Avatar
Re: Throttle Body / Water Crossover Sensor......
I'm a little unclear about what you're referring to but there are basically 2 things going on underneath the TB- the IAC valve (looks like a sensor with a square 4 wire plug) and in-and-out coolant lines which feel engine coolant through the TB to keep it from icing up on VERY VERY cold days.
The IAC (Idle air control) servo is how the ECM controls idle speed- faster when cold, slower when warm, as well as compensating for engine load in-gear and when the A/C compressor kicks in.
The coolant lines going through the TB you can leave off completely unless you drive the car in viciously cold weather. That's what's referred to as doing the "Throttle body coolant bypass" mod. It's one of the "free mods" often referred to that you can do to TPI and LT-1 engines.
Old Jun 13, 2005 | 06:07 PM
iansane's Avatar
Looks like Damon explained it quite well. That sensor isn't a sensor, it's the IAC. I had a similar problem with my HSR and swivel water neck so I pulled that whole assemly off the TB and cut off everything but a few bolt holes to hold it on and the IAC valve. I got rid of the coolant passage and I haven't had any problems.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
