tpi motor
Old May 18, 2005 | 09:37 PM
aces&eights's Avatar
tpi motor
I was wondering what it would take to put 330 rwhp to the ground threw a tpi setup. Some limitations though are below 5500 rpm 1 5/8 inch headers and a tight converter.
Old May 18, 2005 | 09:56 PM
doug791's Avatar
Re: tpi motor
Is this in a 305 or 350? im gonna say for a 350 cause a 305 is a lot harder.
350 you would need a 3" exhaust (y pipe flows just as well as duals) and you cant have obstructions like a tiny cat. You would need a new intake or at the very least to port your intake base and runners. That combined with either ported stock heads, or stock aftermarket heads something relatively cheap, and an lt1 cam should get you where you want to be.
Old May 19, 2005 | 07:54 AM
87DJP2001's Avatar
Re: tpi motor
If you have the money anything is possible. But with a stock motor and dong nothing internal you are not going to make your quoted number much less at the Rear wheels. you will need at least 400 + Hp at the flywheel and that is a reach.
Old May 23, 2005 | 11:51 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: tpi motor
Follow my combo, except substitute Trick Flow heads instead of Corvette heads. Mod list is in the link in my sig.
Old May 24, 2005 | 12:32 AM
doug791's Avatar
Re: tpi motor
If you dont even have the money for a hi flow converter, then you pretty much have enough money to buy winshield washer fluid. Buy the yellow stuff, i hear it gives you 20 hp.
Old Jun 1, 2005 | 10:04 AM
dcrews's Avatar
Re: tpi motor
i do believe tight converter means TORQUE converter
Old Jun 1, 2005 | 11:49 AM
guywithaZ's Avatar
Re: tpi motor
Is nitrous an option cause that would make a whole lot easier...
dfarr67
Apr 10, 2015 07:44 PM
capebuf
Jan 13, 2015 07:22 PM
4586
Dec 6, 2014 05:20 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
