cooling fan problems
Old May 22, 2005 | 09:00 PM
red89iroc350's Avatar
first i'n new here, secoundly i have the duel fan setup in my car, well neither fans go on even with the temp sensor in the pass. hesd is grounded out. also when i try to pull codes the fan doesnt go on either like it should. i changed the relay and dont know what else it could be. thanks for the help.
Old May 22, 2005 | 09:43 PM
89_Irocz's Avatar
Re: cooling fan problems
Do they come on with the AC? Are you getting power to the fan motors? Are the motors good?
Old May 22, 2005 | 09:54 PM
motors are good and they still dont come on with the ac on
Old May 22, 2005 | 10:01 PM
89_Irocz's Avatar
It still sounds like a relay problem but you say you checked it. See if you have power leaving the relay, then see if you are getting power to the motor plugs to see if you have a broken wire... Goodluck
Old May 23, 2005 | 03:35 AM
Black305RS's Avatar
there is a sensor underneath the passenger side exhaaust manifold that triggers the fans on when coolant temp reaches x amount that is the problem. you can fix it by replacing it or do what i did and make a manual fan switch.
Old May 23, 2005 | 04:32 AM
masiroc566's Avatar
I have a new sensor for your car if your interested!! Let me know!!
Old May 23, 2005 | 07:56 AM
i just replaced the sensor in the passinger side of the head and still nothing. i'm just going to buy 2 new relays and see what happends
Old May 23, 2005 | 04:41 PM
89_Irocz's Avatar
thats the best thing to do.... Hope you get that 350 cool....
Old May 23, 2005 | 10:17 PM
ok i put in the 2 new relays and still nothing, the fan motors themselves work but there is no power getting to the fans. and i'm out of ideas
Old May 28, 2005 | 04:59 AM
Mrichar8's Avatar
Have you checked the fusible links in that circuit? I think they are next to the battery or down by the starter.
Old May 29, 2005 | 09:54 PM
camaroken's Avatar
Don't confuse yourself with the turn the ac on thing. If the ac is low on freon the clutch will not turn on and cycle anyway. the cutout switch will prevent the fans to come on at that point. your problem seems to be electrical. relay fuseable link, possibly as simple as a fuse. pull the relay out and jump it from the hot terminal to the trigger terminal and see if it kicks on. I'm not sure as of yet on the config on your car but start there. the easiest thing to remember about electrical is you need a power and a ground to make something work and a relay is nothing but a switch. use a test light and see if you got a power and a ground at the relay first, if you got + and - then the one of two remaining terminals trigger the fan on and off like a switch. hope this gives you the basics, it seems like a simple problem to me, but it took me years in the trade to get it and typing it as opposed to being there to fix it or show you is a little tough. a good luck. let me know what you find.
Magenta_Hearts
Mar 29, 2017 08:54 PM
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
bernie1951
Dec 10, 2014 10:03 AM
