Cam for my engine???
Old Jun 3, 2005 | 11:42 PM
SLOW84TA's Avatar
ok I have everything for my combo set and need to just work out the cam specs. Now details about the engine so you know.
Its a 400 small block bored 30 over to 406.
6inch Rods, KB Dome pistons with AFR 210cc heads, 2.08 intake and 1.80 exhaust valves.
Looking at around 11.2:1 CR
Victor JR intake with Holly 850cfm Carb
with a t56 & 3.73 final gear ratio
Look at Mechanical Roller Cam & Lifters
this kit is what appears to make the best power from what my engine dyno estimation software and compcams tech tells me. Looking to break 600hp.
http://www.compcams.com/Technical/Se...umber=12-773-8
Please I would just like to know what everyone thinks? As well as any suggestions you might have from personally experiences
Old Jun 4, 2005 | 05:25 PM
AutoRoc's Avatar
Re: Cam for my engine???
I have that cam in a 396 but it's not running yet. Dart 230 head, Super Victor, 11.5:1 compression, long tubes. Not sure if it will make 600+ but it should be damn close.
Problem is you haven't told us if it's a race car or street car, double duty? etc.
WHATEVER it is for. A T-56 car like that needs more gear to go through the traps at a good RPM on 26" tall tires.. Even steeper gears if you are doing a 28" tall tire. 4:10 or 4:30 if you end up with a more aggressive cam and more RPM. Goodluck!
Old Jun 4, 2005 | 06:32 PM
doug791's Avatar
sorry this is post whoreing a little bit just wanted to say thats a ****ing awesome setup. Not worried about breaking that t-56 with 600 hp?
Old Jun 4, 2005 | 07:56 PM
SLOW84TA's Avatar
thanks for the props. yea I'm sure it'll be fun. It'll be a double duty. More of a street car and goto the race track for fun type deal..
when I get a better rearend I'll probably be going with 410s
Old Jun 5, 2005 | 10:10 AM
blown3rdgen's Avatar
Make sure you use the right valve springs! I've run 3 of the extreme energy cams. Great street/strip cams- up to 6000-6200rpm max. After that I would get valve float. I think it was because they used such fast opening and closing ramps. This was however on a hyd roller set up not solid roller, which should help you up top. I'm guessing with those heads and intake and a goal of 600hp you're going to need something that will pull to like 6800ish. Maybe look into some kind of stud girdle for valve train stability.
Matt
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
