Engine Swaps
Old Jun 8, 2005 | 06:19 PM
87TransAmGTA's Avatar
Engine Swaps
What engines could I swap in my car, and could i keep the 5 spd if possible with any other engine? I was thinking of getting one of those buick grand national engines, i know some trans am's had them and they ran a low high 13- low 14 stock.
Old Jun 8, 2005 | 06:45 PM
87DJP2001's Avatar
Re: Engine Swaps
another one of those "I want".
Old Jun 8, 2005 | 06:52 PM
Pneumatic_Tire's Avatar
Re: Engine Swaps
I suppose you never had an idea on something to do to your car.
Old Jun 8, 2005 | 06:57 PM
angel71rs's Avatar
Re: Engine Swaps
I think the head castings on the 89 TTAs were different than the GN heads for clearance reasons. So you'd have to fork over a gonad to make this happen. If you want more power, and don't want to go with a bigger sbc, go for an LSx. LS1tech.com has an engine swap section if you want to investigate.
Edit: forgot to add: buy an engine/tranny unit so you could go 6 speed.
Old Jun 9, 2005 | 05:38 PM
84Stang Slayer's Avatar
Re: Engine Swaps
hey i have a 84 Z28 and if you want to swap engines DO NOT put a 3.8 out of a grand national in it, for the price you would pay for a rare engine like that i would build a 327 small block, Not a 350 or a different 305 the shorter stroke of a 327 gives you a higher rpm and top end power that cant be beat
Old Aug 25, 2005 | 05:14 PM
Calico's Avatar
Re: Engine Swaps
go over to turbobuick.com...this has been done many times over look for a guy named flyingta...you must stick with either the 700r4 or the brf 200...if you go with the inferior 200 then you need a driveshaft, cross memeber and other things specific to the 89 TTA...(yes gm made one) some of the parts are available oem!
Old Aug 28, 2005 | 01:23 AM
2 z28s's Avatar
Re: Engine Swaps
build a 350, they are cheap n easy to come by and it will match up to ur t5
Old Aug 30, 2005 | 01:23 PM
Tru2Chevy's Avatar
Re: Engine Swaps
How about some details about your car? Is it a v6 or v8? Other details like this would help....
- Justin
Old Aug 30, 2005 | 06:44 PM
nj85z28's Avatar
Re: Engine Swaps
- Justin
truth.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
