3rd Gen "Choke" light
Old Jun 11, 2005 | 11:28 PM
ukeman's Avatar
My son and I have been rebuilding an '86 3rd IROC - new 350, Edelbrock Carb w/ electric choke, new distributor.
Lately the Choke light has been coming on - was causes this?
Old Jun 12, 2005 | 01:07 AM
Solidous_Snake's Avatar
Re: 3rd Gen "Choke" light
I'm going to read to you what the owners manual says about the "choke" light:
All vehicles (except electronic fue injection vehicles) are equipped with a choke warning indicator light in the instrument cluster. The light should come on when the ignition is turned on, to provide a "blub check", but should go out after the engine is started. If the light fails to come on with the ignition turned on, it could indicate a burned out blub, a defective electric choke heater circuit or a blown instrument lamp fuse.
HAVE SYSTEM REPAIRED IF LIGHT DOES NOT COME ON DURING CHECK
If the light comes on during normal operation, the engine should be stopped and the trouble located and corrected.
NOTICE: Continuing to run the engine eith an illuminated CHOKE" light can cause unusually high exhaust system temperatures whch could result in serious damage to the vehicle.
That's all they say about it. Hoped it helped a little. Basically, I wouldn't have the car running any longer until you resolve the issue.
Old Jun 12, 2005 | 03:30 PM
Marc 85Z28's Avatar
GM also used the CHOKE light for a charging system warning. Low voltage will also turn the light on. Check the choke, then the charging system, and if you find no obvious problem, do a search on this topic here. The CHOKE light circuit is a little complex, and there has been a decent amount of posts on it.
Old Jun 12, 2005 | 03:34 PM
NJSPEEDER24
Guest
Posts: n/a
this is correct
Jul 4, 2005 05:00 PM
19redta96
Jul 23, 2002 12:25 PM
JasonD
Jul 15, 2002 02:17 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
