Charging problem..
Old Jun 4, 2005 | 08:37 PM
bigshow31069's Avatar
Charging problem..
I swapped a 2.8L FI to a carb. 350, the alternator plug from the 2.8 is a 3 wire plug, I'm now using an older style alternator with a 2 wire plug, does anyone know the wiring conversion to go from 3 wire to 2 wire?.. any help appreciated..Thanks
Old Jun 5, 2005 | 09:55 AM
blown3rdgen's Avatar
Re: Charging problem..
Since you did the motor swap to carb 350, I'll assume nothing is computer controlled. I also assume you are using the older "cs" style alt which is self exciting.
I would not worry about that 3 wire plug at all. Basically you just need to run a power wire (8-10ga) from the battery to the power teminal on the alt (threaded terminal probably marked B+). You can then run another wire from that power terminal to the #2 spade terminal. You can run a wire from the #1 spade terminal to your gauge or just tap in somewhere under your dash.
Matt
RUENUF
Mar 13, 2016 03:37 PM
68camaroboltz
Oct 5, 2015 01:46 PM
cmsmith
Sep 14, 2015 09:25 PM
WPHIG2
Aug 27, 2015 06:37 AM
Boss002
Jul 24, 2015 10:47 AM
